I made myself a record cleaner
Old 3rd April 2008, 11:40 PM   #31
Baxthorpe is offline Baxthorpe  Scotland
While I must applaud the ingenuity, I have to offer a voice of caution about the use of alcohol in the cleaning solution.
Ultrasonics are commonly used in laboratories to aid the solvation of substances that are difficult to dissolve. I would fear that the ultrasonic bath might help the alcohol dissolve components of the vinyl.
A little alcohol in a solution used in an Okki Nokki will not do much harm, but it could be very damaging in conjunction with the ultrasonic effect.
I have no direct evidence to support what I am saying - but I would be very nervous about using alcohol in the cleaning solution.
Old 4th April 2008, 01:34 AM   #32
dnsey is offline dnsey  United Kingdom
Beautifully constructed!
For the removable shaft drive, why not cut slots in the outer tube, and fit a short pin in the inner.
Old 4th April 2008, 07:19 AM   #33
Shaun is offline Shaun  South Africa
Shaun's Avatar
Very lovely, Sclalars!
You are doing what I have been wondering about ever since I first saw an ultrasonic cleaner. The problem with that cleaner was that it was used as a degreaser with freon, initially, and later a more environmentally friendly liquid. This setup would have destroyed the vinyl for sure.
Good going. You have me at the edge of my seat
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 4th April 2008, 12:44 PM   #34
240z4u is offline 240z4u  United States
Send a message via AIM to 240z4u
While I do love my VPI setup, something that will do multiple records and not sound like a hurricane coming through my apartment would be great.
Keep us updated!
Evan
Yeah... it seemed like a good idea at the time.
Old 4th April 2008, 02:20 PM   #35
audio-kraut is offline audio-kraut  Canada
Thanks for making that clear. I have used Isoprop in 50% solution to clean records for the last 50 years, and have yet to encounter a record damaged through the solution.
Old 4th April 2008, 02:27 PM   #36
despotic931 is offline despotic931  United States
despotic931's Avatar
Send a message via AIM to despotic931
I am curious to know what makes you nervous about using alcohol if you have no direct evidence? I have a buddy who swears by alcohol pads to clean his albums.
Old 4th April 2008, 03:01 PM   #37
Sclalars is offline Sclalars  Norway
Yesss, that's the the way to do it, or at least something similar. I did try to remove the metal tube, and just made a split in the acrylic tube, and it was a success
Thanx dnsey!
Old 4th April 2008, 03:09 PM   #38
Thank you Shaun!
Here is my first idea of a washer. A hand turned one:
Would probably work also, and are easy to make.
Lars
Old 4th April 2008, 03:21 PM   #39
Isoprop combined with distilled water is the most common prescription to clean records here in Norway, so I'm not that anxious about this issue.
Lars
Old 4th April 2008, 09:45 PM   #40
Audiomix is offline Audiomix  Norway
The mixture is 7 parts of destilled water (or norwegian spring water!), 1 part of alcohol and a little synthetic detergent. Just enough to break up the surface.
After we have heard som concerns about erroding the vinyl, we will do some long term testing to see.
Will you let me do the testing Lars?
I made myself a record cleanerHide this!Advertise here!
My DIY record cleaner. mattjk Analogue Source 105 9th March 2016 04:05 AM
When a Kenwood record cleaner-to be becomes a Garrard 301/Thorens TD124 Hybridmonster happycat Analogue Source 40 4th August 2015 07:27 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 03:28 AM
DIY Record Cleaner Machine cactuscowboy Analogue Source 19 3rd August 2009 05:15 AM
Inverting rotation of a VPi record cleaner m.parigi Analogue Source 4 29th October 2003 08:11 AM
