| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#111 |
Nice work Ianmac. I am building one of these units myself. Have you played around with temperature in the bath, or have you used any surfactant or detergent?
#112 |
We use one part of alcohol to seven parts of water.
Clean water should be good enough because of the ultrasonic action.
Hans |
#113 |
AudioDon
Haven't played around with temperature. I don't have a good knowledge of Chemistry so am enlisting the help of a retired Chemist re the addition of alcohol as recommended by a number of subscribers. Am intending to try the 1 in 7 mix mentioned by Audiomix. Currently getting good results with Scottish tap water - which is similar to the Norwegian variety !- with a tiny drop of washing up liquid With the number of users of Ultrasonic cleaners increasing by the week we should be able to pull together a list of recommended cleaners and procedures! Ianmac |
#114 |
Scottish tap water? Is that alcohol?
#115 |
Regret no, basic water from Loch Katrine. Have not tried to add some malt whisky yet.
Got some Isopropol today and mixed it with water on a 1 to 7 ratio. with a drop of detergent. Excellent results. Looks like the core recommendation from earlier subscribers is well within the ball park. I have not tried varying the temperature, bearing in mind the temperature of the solution does rise slightly in use. One tip I did pick up from a UK electronics Co. that sells Ucleaners was to degass a cleaning solution before using it. They recommmend running the cleaner for 5 mins each time a new cleaning solution is loaded before using it for actual cleaning. Ianmac |
#116 |
Thanks for the response. Just wondering if anybody can elaborate on the action each of the ingredients will contribute. I believe I understand the action of the alcohol is to degrease by dissolving oil; not sure about the detergent.
When detergent is used would it not be necessary to do a rinse on the vinyl afterwards, perhaps using a VPI vacuum machine in conjunction with distilled water? |
#117 |
The detergent is used as a surfactant to break the surface tension in the water. You do NOT want it to "sud" or bubble.
The idea is that if the water still beads up it will not get into the microscopic groves - 10kHz and above. So a drop or two makes it so the water is slick but not suddy. Basically before you add the surfactant a water bug could probably walk across the top but after I think he would break through the top of the water and fall into the water. |
#118 |
Hello, my name is Tom and this is my first post here. I have been following this post for a while.
Here is a link to the US Record Cleaner I am working on. http://www.hillman-rls.com/Ultrasoni...aner/Index.htm Be gentle with your critiques and good advice is always welcome. |
#119 |
Awesome job Tom , no critisism here.
What do you use for cleaning fluid and at what temp do you clean at? I just completed a ultrasonic cleaner myself and will post some pics. next week. Great job.!!!! Todd |
#120 |
Thanks Todd. It has taken me a while to acquire everything needed for this project. I started collecting parts of it before Christmas.
I just want to say thank you to all you guys for contributing to this thread. Thanks Lars for starting this thread and posting your unit, it looks great. Thanks as well to Ianmac; I know you have been working on yours for a while, Great job. Also thanks to the guys over at hifisentralen.no (Lars and others). A lot of good designs over there as well. I just wish I could read the language, but the pictures are pretty, lol. I really haven’t used it that much to come up with a cleaning solution. We have a reverse osmosis hooked up to our kitchen sink. It is a 6 stage unit with 2 de-ionizing filters on it. When I tried it last night I used the RO water with a couple drops of Dawn dishwashing detergent. I did not like the foam so I sucked it off the top of the bath. I then added some PhotoFlo and that seemed to be the ticket. I will be experimenting more tomorrow. Be sure to wear your ear plugs when using this type of cleaner. I have more ringing in my left ear today than usual. |
| My DIY record cleaner. | mattjk | Analogue Source | 104 | 26th April 2013 09:10 PM |
| Ultrasonic Record Cleaner- any feedback | Ianmac | Analogue Source | 7 | 13th November 2012 03:28 AM |
| When a Kenwood record cleaner-to be becomes a Garrard 301/Thorens TD124 Hybridmonster | honinbou | Analogue Source | 36 | 12th October 2012 09:43 PM |
| DIY Record Cleaner Machine | cactuscowboy | Analogue Source | 19 | 3rd August 2009 05:15 AM |
| Inverting rotation of a VPi record cleaner | m.parigi | Analogue Source | 4 | 29th October 2003 08:11 AM |
