Old 28th March 2008, 08:07 PM   #1
Default Belt tensioner makes wonders!
I saw herr Schroeder's smart implementation of the belt tensioner principle while back at Audio Asylum. Advantages seemed so obvious, so it made me try on my own. My design is rather straightforward: constant gravity force is applied to the rocker sector with the tensioner pulley on it, by means of the weight hung on the silk thread.
It was a real PITA to adjust the mechanism to get two pulleys axles exactly parallel (otherwise belt runs up or down); I should make the basis adjustable. Eventually, it was all set; two seconds after the needle dropped on the record, I knew I have a major sonic improvement!
Week of intense listening only proved the first impression: each and every component of the sound picture got better, especially:
- lightning speed with razor sharp leading edges and proper decay (crucial importance for piano records),
- no smearing between single notes during arpeggio(never heard it before),
- large scale orchestral music became clearly delineated between instrumental groups and between players within each group,
- much better defined bass,
- sound color scale and texture largely improved.
And all this because of simple tensioner? It keeps to amaze me.
Old 29th March 2008, 01:49 PM   #2
marekst is offline marekst  Poland
marekst's Avatar
Hi Michael,
Very nice!!! I can’t open the picture but I’ve seen it on audioasylum.
I made precision motor distance adjustment for my TT and it is not enough - I found out I need some kind of belt tensioner. Thermal expansion of platter changes belt tension too much to ignore it. I also like your idea of increasing belt contact surface with the pulley.
What weight do you use?
Marek
http://gallery.AudioAsylum.com/cgi/v...=21150&invite=
Old 29th March 2008, 02:17 PM   #3
mmm, I read a about this - seems like it would be ideally suited to my Teres as well.
Are you using magnetic tape for yours livemusic? I tried some video tape and it "rustled" quite a bit as it turned. Have you had this issue?
Fran
Old 29th March 2008, 02:22 PM   #4
Thanks Marek,
The weight is about 100 gramm, and since the tensioner pulley sits twice closer to the rocker axle than thread connection point, it gives 200 gramm on the pulley. By simple math it is equal to 65 gramm of the belt tension force, 130 gramm of side force on the motor axle and 84 gramm of side force on the platter bearing.
I belive this mod may be easily implemented by average DIY'er and for the profound effect it makes, it's a killer tweak!
One tip: use the Maccormik 1/2'' mylar tape for belt; it is thicker than VCR tape and suit this tweak nicely. I tried to use it with no tensioner - it slips!
Michael
Old 29th March 2008, 10:40 PM   #5
marekst's Avatar
Old 30th March 2008, 12:57 AM   #6
OK, I think if I am to make this I will use a tensioner from a tape machine of some sort. Maybe use a spring loading instead of the counterweight if I can find something that easy to adapt.
BTW, where did you buy the McCormick tape from? I'm using some 1/4 clear tape leader at the moment, but have a 1/2" pulley installed.
Fran
Old 30th March 2008, 12:52 PM   #7
Livemusic, that's very clever! One thing that did cross my mind was that as the ends of the belt are close together, will there be a more even loading of the platter bearing compared to the more conventional belt arrangement where there is more loading to one side?
Si.
Old 30th March 2008, 02:59 PM   #8
Fran,
Here is the link:
http://www.mccormicksnet.com/Product...139&ItemID=196
Harwoodspark,
It depends. With all being equal, you have to have certain wrap angle to preclude the mylar tape from slipping on driver pulley (unless you are not using rubber belt - the worst option). To obtain this angle, motor is usually placed rather far away from the platter. With the tensioner, the idler pulley is getting much closer to the platter, increasing the angle between belt "tangents", and the forces parallelogram got "squeezed". So for the same minimum belt pre-tension force required to eliminate slipping, the platter bearing side loads become smaller.
Old 31st March 2008, 12:15 PM   #9
marekst's Avatar
I have tried holographic mylar from mccormick - it wasn’t straight and the edges were wrinkled - the tape is meant to be used for decoration. You may like what I use - ˝” poly leader tape (audio product, made in Germany) a bit heavier, stronger and straight. I bought it from eBay store run by seller “xiat”. I got a remnant for a penny, normally he sells it on a big spool hence the high price.
Marek
Old 3rd April 2008, 05:47 PM   #10
ckniker is offline ckniker  United States
Default source for idler pulley?
I also have a Teres motor and would love to try this tweak on my own setup.
Where can you find the idler pulley and shaft? I've done a fair amount of googling but haven't found the right parts yet.
Thanks in advance,
Chris
Belt driven Motor placement and belt properties luvdunhill Analogue Source 2 16th July 2008 05:21 PM
Newb wonders: Class T or Gainclone better for monitoring? lossfound Chip Amps 4 27th September 2007 06:12 PM
line array...$1 wonders parts express johnnyb831 Full Range 9 2nd May 2006 04:18 AM
How great are the 69/49 cent wonders at Parts Express? mazeroth Multi-Way 2 25th August 2004 08:35 AM
Time for wonders - New datasheet LT1115 peranders Parts 8 28th December 2002 01:45 AM
Page generated in 0.11517 seconds (79.41% PHP - 20.59% MySQL) with 11 queries
