| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#61 |
Whatever you guys decide on, I hope it's cheap and will work with the 16 pole BIC motor in my project.
#62 |
Everything discussed so far is too expensive or too hard for my tastes
![]() Can it be simplified to the point where just a single LM1875 is set up as a Wein bridge oscillator driving a transformer? Is there a pitfall? I guess one question I have is the tracking error of a typical stereo pot (to vary the "R" and thus frequency) would result in oscillation.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#63 | |
#64 |
Tracking error of the tuning pot is no problem concerning stability. It only changes the loop gain somewhat but that is accounted for by the lamp stabilisation.
In my design the bridge was dimensioned by fixed resistors and the pot was just to trim de speed plus and minus approx 5 %. I have no drawn schematic of it, it was just build straight away. If it helps I can draw a schematic, but that will not exactly reflect the thing of 10 years ago. So some fine tuning/experimenting yourself is needed to get it working properly. Cheers
#65 |
Thanks. I actually forgot about your post. I saw this in a web search and I though it might be even better than using a lamp to stabilize the oscillator:
http://www.calvin.edu/~pribeiro/cour...ion-Darren.ppt
#66 |
Hello Mark Kelly, I am trying to contact you regarding the power supply of my PT turntable. I am unable to sent you a PM on this board as I have not made previous posts. I believe you are a busy person but if you could contact me I would greatly appreciate it. I live not that far from Geelong in Lorne.
Apologies to people in this thread for this post but I couldn't think of another way of contacting Mark who I think looks at this board fairly regularly. Cheers Michael Anderson |
#67 |
You have mail
#68 |
| motor control in 3 location | engel dela pena | Everything Else | 1 | 29th December 2008 06:15 PM |
| DC motor speed control | winggo | Analogue Source | 13 | 25th August 2008 01:48 AM |
| LAG668FT amp/motor control IC | Pillimees | Parts | 0 | 26th February 2008 09:43 AM |
| Help with control a Stepper motor with an IR-control. | Progg70 | Parts | 1 | 17th August 2007 05:15 PM |
| PLL motor control | HFGuy | Analogue Source | 4 | 14th July 2005 03:12 PM |
