Old 28th February 2008, 10:18 PM   #1
Default Relating mic sensitivity to output voltage
I wanted to get an idea of the range of output voltages from microphones, so I did some searching, but I'm having trouble relating mic sensitivity figures to voltage. Can someone tell me what I'm missing in this calculation?
As a random reference, I looked at the specs for a Neumann U87ai, from their website.
-Using cardioid pattern, sensitivity is 28mV/Pa
-Max SPL is 117dB
-Max Vout is 390mV
Here was my logical thought process, which obviously is flawed somehow:
1 Pa is the pressure produced by 94 dBSPL
117dB = 94*1.244, so 117dBSPL should produce 1.244 Pa of pressure
With a sensitivity of 28mV/Pa, 28*1.244 = 34.8mV at 117dB
But they state the max output is 390mV.
So where did I go wrong? If I find a microphone spec that doesn't list max output voltage, how do I correctly convert the sensitivity to a maximum output based on the maximum SPL?
Old 28th February 2008, 10:25 PM   #2
xiphmont's Avatar
Send a message via AIM to xiphmont
decibels are logarithmic. 20dB is a factor of ten. 40dB is a factor of 100, etc.
.390v / .028v is a factor of 13.93. a factor of 13.93 is a shade under 23dB
117dB - 94dB = 23dB
It all matches up.
"My name's Monty, and I break things."
"Hello, Monty!"
Old 29th February 2008, 04:24 PM   #3
Equation relating t/s parameters to sensitivity vs frequency thadman Multi-Way 7 22nd November 2008 07:44 PM
newbie question : driver/output relationship, input sensitivity mahleriana Tubes / Valves 1 17th August 2008 08:10 PM
Relating SPL to Force? Kaoss Multi-Way 4 13th August 2008 04:17 AM
Math to calc optimal voltage of tube dac to match amp input sensitivity? riotubes Tubes / Valves 7 9th November 2006 11:08 PM
Question(s) relating to monitor loudspeakers ERICSPEEd Multi-Way 0 30th May 2005 03:48 AM
Page generated in 0.06549 seconds (68.69% PHP - 31.31% MySQL) with 10 queries
