good place to buy acrylic for DIY TT
Old 1st March 2003, 03:16 AM   #1
ironcitymadman is offline ironcitymadman  United States
Question good place to buy acrylic for DIY TT
Hello all!!! This is my first posting. I've been intently reading all the DIY TT threads, and the thought of making my own TT seems HELLACOOL I need a little help in finding a good place to buy acrylic. Is it all the same? (quality, density, etc) Also how do you samich metal (ie aluminum, stainless) to plastic for a platter? Glue?Screws? Sheer will? thanks for any help
BEER
It's a burgh thing
Old 1st March 2003, 05:43 AM   #2
On Hiatus
SY's Avatar
McMaster-Carr has all. So does TAP Plastics. There are a lot of grades of acrylic available, both filled and unfilled. Horses for courses- there is no "best," only good and bad choices for specific applications and design tradeoffs.
There are a lot of options for metal-to-plastic attachment. Screws, certainly (though one has to be mindful of torque and design in a way of spreading out the force). Adhesives, too- being careful to allow enough compliance to not have failure from mismatch of thermal expansion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 20th March 2003, 02:44 AM   #3
Vinyl-Addict is offline Vinyl-Addict  United States
Default Acrylic material selection
I highly recommend CAST Acrylic Sheet. That is what I use in my machining projects. Look for Lucite L Cast Acrylic sheet. If you have never worked with Acrylic, be careful, do not drill pilot holes and then chase them with larger drills unless you have the work held down securely, otherwise it will suck up and cause you injury. Acrylic will also crack if you don't have a good method of drilling. It saws easily and machines well, but you must have a good process in mind before starting the project. Good luck!
Old 20th March 2003, 02:47 AM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
good place to buy acrylic for DIY TT Send a message via AIM to Peter Daniel
Default Re: Acrylic material selection
Any recommendation on drilling speed and lubricants if any? Sometimes I got chipped edge on a hole, but usually it's fine.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th March 2003, 08:31 PM   #5
Default Drilling speeds/methods
I would perform a search on google to find specific speeds for drilling since I only deal in SFM to calculate drilling speeds and feeds on CNC equipment. I also use water soluble coolant when drilling/machining all plastics and metals.
Are you doing this project in a garage and using hand tools?
1 important thing that will help you obtain good entry and prevent chipping when the drill goes through the workpiece is to place a plate underneath the piece you are drilling. That will support the acrylic when the drill breaks through the other side and prevent chipping. Also, do not drill a small pilot hole and then chase it with a larger hole. You will chip the material as well as risk the drill sucking into the work. Good drill point geometry for the drill should be between 60 & 90 degrees. Finally, always make sure you have a sharp tool.
Old 20th March 2003, 09:33 PM   #6
grataku is offline grataku  United States
I just got done making some pieces of equipment with acrylic. After drilling and before glueing remember to anneal the part with a heatgun. ~50-60 C should do it.
Old 20th March 2003, 10:23 PM   #7
Default here is a link
Here are links with some info on working with Acrylic.
http://www.eaa1000.av.org/technicl/acrylic.htm
http://www.plaskolite.com/fabguide/pg08.pdf
Old 13th April 2003, 06:05 PM   #8
JOE DIRT® is offline JOE DIRT®  Canada
JOE DIRT®'s Avatar
If anyone cares on my input here......LEXAN is the best acrylic to work with....it can be machined,threaded,formed and the stuff is bullet proof...I currently buy it for my designs at 200CAN for a 4X8 sheet...I have done pretty much everything with this product....nice thing about it also is it comes with a peel off plastic backing so it does not get scratched....it also comes in different tints as well as clear...the trademark is owned by 3M but there are other manufactures that have a similar product
Cheers!!The DIRT®
Old 14th April 2003, 12:10 AM   #9
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default LEXAN.
Oh, yes...almost forgot about Lexan.
Excellent idea.
Thank you for the reminder.
Frank
Old 14th April 2003, 01:21 AM   #10
I didn't check it myself, but acrylic probably has better damping properties and sounds better than Lexan. You can even feel the difference when handling both. Here's my recent baffles, machined out of 2" acrylic.
www.audiosector.com
good place to buy acrylic for DIY TTHide this!Advertise here!
Toroids, where's a good place to get them? stryperfreak Parts 5 12th December 2007 07:14 AM
looking for place selling metal/acrylic scrap in Vancouver Canada happycat Everything Else 2 14th October 2007 03:34 PM
Where is a good place to get PCBs manufactured? turbo_slug Parts 12 21st March 2007 05:59 PM
3/8in thick acrylic - would this make a good chassis? jarthel Tubes / Valves 8 22nd May 2006 02:34 PM
good place for transformers zx3chris Parts 8 10th February 2003 05:18 PM
Copyright ©1999-2017 diyAudio
