| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hello,
I recently acquired the Thorens TD320 with TP16 MKIV arm. I also bought the denon DL103 cart that I would like to use. But when I install the cart it is to close to the record surface. In fact it touches. I did not receive the spacers as they are talking inside the manual. Has anyone idea if one can lift the arm so it does not touch. If not is somebody using the same configuration and is there somewhere the place to buy these spacers. What is the height you use? Thank you in advance, Pred |
#2 |
At the base mounting plate of the TP16 arm there are 2 small hex screws (below the gymball). If you loosen these screws you can move the complete arm assembly up and down.
After adjusting the arm height you will probably need also adjusting the arm lift height. |
#3 |
Thanks for the help,
I tried to loosen those screews (hidden below this thing at the base of the tone arm) but I can not. They are tight and I am affraid to brake them. There are two, smaller ones (1mm or so) higher on the tonearm but those if I loosen nothing moves Regards, Predrag |
#4 |
Hi Predrag,
You need the lower 2 ones just above the base of the TT. You need to turn them counter clockwise like loosening any normal screws. They will loosen the complete horizontal bearing. Be careful, use a tight fitting hex key of good quality to avoid damaging the screws. |
#5 | |
By the way, I never adjusted VTA of the cartrige any special tips or sites where I can see how it should be... Regards, Predrag |
#6 |
If I remember well the size is 1.5 mm, but I am not sure.
Adjusting VTA is not that difficult. Start with the arm in parallel with the record when the cart is on the record. Then adjust height so both the lower frequencies and upper frequencies sound undistorted. But my experience is that the DL103 is quite forgiving about that. In a technical way, adjust IM distortion to the lowest value with a IM test track of a test record. For that you'll need a spectrum analyser or a soundcard with some audio analysing software. But maybe this is a few miles too far for the moment. |
#7 |
Hello,
just to report I took the wrong screwdriver today (1mm) instead of 2mm which is the size. With a small one L shaped thing you can by everywhere the 2 screws in the bottom do not want to move a bit. I was afraid to force them too much and kill the screw. I will get the right one tomorrow and try. Then I will report if I had a success. Thanks for the tips on the VTA. Regards, Predrag |
#8 |
Hello,
I found a good screwdriver, wanadium thing... It so bended when I applied the force that I thought it will break Now, when I am so high the VTA must be off since the tonearm comes at a high angle to the record surface. I made a small acrylic spacer (3.5mm) at work that I will try tonight to lower the DL103 down and see if there is a sound comming out I did all during my lunch brake (I ate the sendwich while driving at noon from work to home I am just amazed nobody has seen this over the net with dl103 and TP16, and I was quite sure I searched a lot. Or there is something wrong with my tonearm. I will do the photos next days and send them so you can see how it looks. Is there a place to by the original spacers (that are mantioned in the manual but I did not get them from the guy on the ebay) that came with thorens? Thank you for the big help on the first part of solving the problem. Regards, Pred |
#9 |
Now i tried, it seems my phono stage is quiet enough to amplify the thing, sans problems. But the cartridge does not track at all. I played with the yellow screw on the top of the arm hidden bellow the plastick cap. Should it be loose so the arm moves left and right or should it be tightened. When is loose, cartridge starts to track, but I am afraid if this is the good position?
VTA is off and I will try the standoff on the weekend. I think the original screws are to short for the job but I will try to see how it goes, if not I must start searching for the screws... Regards, Predrag |
#10 |
Ok,
finally I learned a lot about my tonearm, and I think I am more than half way trough. I think VTA is pretty good. I measured the resonance using test record and both vertical and horizontal are 10-11Hz, so quite nice. I am not sure about antiskating but more fun for future... Here is the photo of the tonearm now. |
| Has anyone taken the body off a Denon DL103? | EC8010 | Analogue Source | 56 | 8th September 2011 09:16 PM |
| Fitting of Denon DL103 on ProJect Xpression II | mavallarino | Analogue Source | 13 | 17th December 2009 02:52 PM |
| Denon DL103, Benz Micro Ace H. Brand new in box. | mattjk | Swap Meet | 1 | 21st March 2005 05:29 PM |
| pearl phono and DL103 | joe845 | Pass Labs | 3 | 22nd November 2004 06:00 PM |
| Cartridge to use in Thorens' TD160/TP16 | Merijn | Analogue Source | 1 | 30th October 2002 09:39 PM |
| Page generated in 0.11481 seconds (79.14% PHP - 20.86% MySQL) with 11 queries |
