| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Seekerr, the last two I bought were at a garage sale and a junk shop. $5 and $10, respectively. Minimal work to get them up and running (new belt, clean up bearings).
If there's a sucker born every minute, where do the rest of them come from? |
#12 |
@SY: I'll try my luck around and about, but I think they may have been rare here in Australia
@simeon_noir, dnsey: I like the look of some of the Pioneers and Sansui's I can see around. Can anyone tell me what the difference is between, say, a PL12-D and a PL15-R? |
#13 |
A Dual 1200 series turntable with a belt drive may have good results for you. They generally need a bit of inexpensive repair, but at long as the motor and spindle are good you may find a good deal. The Dual 1229/1229Q and other idler wheel drive turntables generally need a lot of repair due to their Rube Goldberg internals and should be avoided if you want to stay under $150.
If you can find two broken turntables of the same model, you may be able to use one for parts to repair the other. |
#14 | |
#15 |
http://cgi.ebay.com.au/AR-Acoustic-R...QQcmdZViewItem
I'm keeping an eye on this, but I fully expect it to reach $120 or so based on what I've seen others in reasonable nick sell for just in the last few days. Still, suggestions from people are still useful......the more different options I have, the less likely I'll go and pay too much. |
#16 | |
The technics 1200 can REGULARLY be found here for ~$200 used, and I see the cheaper numarks/geminis sell for ~$100. I'd try to find a technics, as they hold their value quite well while the others seem to come and go like cheap plastic components. It appears the craigslist has yet to catch on much in your area, here in the states it can be a great resource. |
#17 | |
Yup. If the Grado black didn't hummmm on my Rega, it would be damn near my first choice! The cheap Grado sounds really good to me.
Crazy Yankee. |
| Frugal-phile(tm) | jag | Everything Else | 36 | 22nd July 2008 02:46 AM |
| A frugal recycled sub idea | Brisso57 | Subwoofers | 15 | 20th March 2008 08:31 PM |
| All Frugal | loninappleton | Full Range | 18 | 5th February 2008 03:00 PM |
| Frugal sub with old drivers - possible? | 38eighteen | Subwoofers | 16 | 21st November 2007 10:23 AM |
| Suggestions for a new turntable | martinab2 | Analogue Source | 2 | 29th March 2004 12:35 AM |
