| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#51 |
expert in tautology
I don't want "amazing" I want "music"...
![]() Music without any holes, or too much zing on the top, or the "Shure" sound (boom and sizzle), or the Grado sound (all mid, all the time)... few carts I have heard compare with the Koetsu line, and the Black sounds like a more refined and better top end 103... whereas the Rosewood is a bit gentler on the top end than the Black which to me is a bit more dynamic although perhaps not as smooth... at least that has been my perception. All I want is the music to "live" and to come off the disc effortlessly. But that's me and my way of looking at it. _-_-bear PS. the phono stage plays a major role in what one hears, so you have to take everything in light of that... as does the arm and TT... it is a closely coupled sub-system in that sense...
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#52 | |
I'll try to get my hands on a good 103R or perhaps a D then.. Yes the Orsonic is cool looking, and works very well with the Zu. The additional mass made a significant improvement in warp tracking (under damped before) and improved the bottom end significantly. Other changes all subtle were also improvements. Scored a new one on eBay this morning for a reasonable if not stellar discount.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#53 |
Good evening,
other body models of DL 103 in europe: DENON DL 103 WOOD BODY en vente sur eBay.fr (fin le 26-févr.-11 16:13:15 Paris)I made a few in the "cedar burl" |
#54 | |
#55 |
I replaced the body on a DL-103R...on the second try. Bent the stylus and broke it.
![]() It is not easy. The most extreme care when removing the body is paramount. I can't stress that enough. If you think you are being careful when removing the body, you need to be even more careful! Anyway...I bought a second 103R and sucessfully installed a Midas aluminum body. Sent the first 103R to Soundsmith for repair w/ Ruby stylus. There is a video on youtube.com on how to remove it. If I could make one suggestion. At all times you should watch the stylus when removing body from the 103R. If you have to exact any kind of force to remove the body, it means the glue is still holding the body to the cartridge. Go back and use a very fine blade to carefully cut through all the glue on the 4 corners. See the video on youtube.com. An Exact-O blade is not fine enough and that is what I used. Find a finer, but strong blade. The Exact-O medium bent back and forth a lot. Good Luck! Vince AudiogoN ForSale: Midas Denon 103 / 103R
I build, therefore I am. |
#56 |
good night, bad luck for the stylus!
on the picture below with white points and glue the blade I use (not worth going on the sides of the hull, only the blade passing level white dots)
#57 |
It seems many of the wood bodies available are "pressure fit" meaning the tolerance is tight enough that it simply holds in place, I am concerned that this would lead to resonance. Is the pressure fit sufficient? Epoxy glue? What is the consensus?
#58 |
Done it. You need to always look at the stylus no matter what. Clinamenaudio.com has wood body for reasonable price.
Know that this is kind of late reply but wanted to share my experience with you guys. One other thing. Below item works really well with DL103 too. cheap but a nice tweak. http://www.ebay.com/itm/cartridge-is...50770994098%26 Last edited by coolzero; 17th March 2013 at 08:06 PM. |
| DL103 and Thorens TD320 TP16 arm | pred | Analogue Source | 16 | 1st January 2010 08:50 PM |
| Fitting of Denon DL103 on ProJect Xpression II | mavallarino | Analogue Source | 13 | 17th December 2009 02:52 PM |
| can any body help to analise | bigcatdairy | Full Range | 16 | 17th November 2008 09:49 AM |
| Denon DL103, Benz Micro Ace H. Brand new in box. | mattjk | Swap Meet | 1 | 21st March 2005 05:29 PM |
| pearl phono and DL103 | joe845 | Pass Labs | 3 | 22nd November 2004 06:00 PM |
