| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
So, my Dynavector 10x5 high-output MC was about to kick the can (sounded lifeless and had about three years of faithful service) and I decided I'd like to try a low-output MC. I had considered a low-output Benz Micro Ace, but an old friend talked me into the Denon DL-103R.
My setup is a Thorens TD-160 with a Rega RB-250 tonearm, which causes a bit of a mismatch for the Denon-DL-103R, for two main reasons: 1. The Rega arms appear to not allow (at least initially) the proper overhang for the Denon cartridge-- it misses it by about a millimeter. Like Mrs. Annan, the DL-103R is built solid and really old school, i.e., the mounting inset is located really close to the needle, leaving not much room for forward adjustment in the Rega headshell. 2. The compliance of the Denon DL-103R is akin to that of a Pullman Car, that is, it's rated as a 5 x 10-6 cm/dyne which means a high-mass tonearm is required to control this monster. The Rega, at around 12g - 13g (depending on who you believe) is not officially up to the task in it's stock form. Furthermore, I needed a step-up device to address the .25mV output of the DL-103R. After a short commercial break, we'll tell you what happened and hopefully add to the discourse by becoming part of the solution for once. <Insert Cialis commercial here> OK-- here's the schematic for the MC stepup I used, which was provided by Thorsten some time ago. More pictures and clever, snappy narrative to come. Kofi |
#2 |
After building the MC stepup, I ordered the following:
* Denon DL-103R (these guys were really fast). * Hi-Fi News test record * Shure tracking force gauge * Blu-Tack * Rega VTA Adjuster Once all arrived, I started the installation process... Kofi |
#3 |
Getting the old cartridge off was a piece of cake, but they don't make it easy to mount the Denon. Not only are there are there no threaded insets, but there's no actual "hole" either. There's just a half-moon indentation where the screw goes.
Furthermore, it's not an allen key-- it's a tiny slotted screwdriver head that faces downward, where almost no screwdriver can go. Try that with only two hands and a hangover. My solution was to keep the screws in place with a little electrical tape lightly affixed to the cartridge. I just needed to get the nuts started, so the tape worked perfectly. |
#4 |
Applying the correct tracking force was done with the aid of the Shure tracking force gauge. This was pretty easy overall...
#5 |
Final mounting and force setting complete.
#6 |
Now the tricky bit-- getting the cartridge aligned in the headshell.
This took a good amount of time, but I finally got it correct. I was able to get a two-point agreement using the Hi-Fi news protractor, but again, the overhang was short by 1mm (actually, it was more like .8mm). This I didn't sweat. |
#7 |
Finally, I used the Hi-Fi news record to fine tune. I was able to track all of the first side except for Track 9 (the "torture track"), which was expected.
On the second side of the LP, I had expected to find that that the resonant frequency of the arm / cartridge combination was too high, which is exactly what I did find. The initial results were that the resonant frequency was about 17Hz. I was looking for something in the 8Hz - 12Hz range, so I needed to modify the arm to add some mass. Here's where the intense customization came into play. This took lots of time and lots of cash. I bought a milling machine to mill about two grams worth of perfectly-balanced titanium which I then sent through an electrolytic bath (which I also purchased) to ensure proper molecular alignment (good for proper resonance). I affixed the final product to the tonearm at the impedance / resonance peak which was found using the following formula: w = ∫ HdB + ∫ EdD 1 + αT 1 With the help of an electron microscope (eBay) I then fused the mass to the tonearm at the precise point above using a small, but powerful laser (found in trash outside apartment complex). You can see the results below. I admit that it looks like a $.07 blob of Blu-Tack wrapped around the tonearm, but in reality, it cost about $1.8 million after all parts were purchased. Well, in retrospect, I guess you could just use the Blu-Tack. I had to readjust the downward tracking force and the anti-skate once the mass was added, but I was able to get the resonant frequency down to about 11Hz, which is good enough for government work. |
#8 |
Oh!
Notice on the side view of the mounted cartridge that I used some plastic washers in between the cartridge and the arm. This was to decouple the rigid cartridge body from the tonearm-- the body being a much-discussed weakness of the Denon DL-103R. Kofi |
#9 |
Hi kofi,
I run the denon 103 on a SME 3009 III (TD 125), this being a lower mass arm. I tested - watching via the deq 2496 rta and listening - with the audio test record developed by flloyd toole, and found this system just excellent. There might be some resonance below 20 Hz, but the rta not extending that far, I cannot say and it doesn't matter. The pink noise response is almost flat, and the system reproduces to +6db level without audible distortion - compared to the lower levels. Theoretically it shouldn't work, but it does just fine. I also have the dl 103 on another td 125 with the airbearing MG1 arm (also a low mass arm) without any problems. PS - no weight added and welded with any type of machinery. |
#10 | |||
Here's my solution for DL-103s: http://www.tnt-audio.com/sorgenti/analogue_bits_e.html
bring back dynamic range |
| Kofi Annan in: "Kofi's Living Room" | Kofi Annan | Full Range | 5 | 25th May 2008 05:19 PM |
| Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" | Kofi Annan | Tubes / Valves | 135 | 15th October 2007 06:15 AM |
| Kofi Annan in: "300beee!" or "Kofi Gets a Toy" | Kofi Annan | Tubes / Valves | 125 | 25th August 2006 03:39 AM |
