| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#31 |
I posted the J110 curves merely as a point of interest. As you say, at lower levels, linearity will be less of a problem. Here's an LSK170 for comparison.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#32 |
Well, that's very nice. At 8mA, the transconductance seems to be 25-30 mA/V and the curve spacing is relatively even. I assume you picked those constant voltage points with a cascode in mind?
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin |
#33 | |
#34 |
I'm just about finsihed a new layout of the "All American" board, changing the PNP bipolar transistors from 2SA965 to MPSW56 and substit\uting a new fast shunt regulator for the series regulator used on the original board. If anyone is curious about the new regulator, I'll post a link to the thread in the solid state forum - simulations looked very promising.. This will all go in a new case with a discrete active crossover so I can ditch my discrete crossovers and go biamp. In the process f stuffing the new board, I can develop an post a selection metod for the fets I'm using for the gain stages.
| Kofi Annan in: "Cascodin' with Steve Bench's RIAA!" | Kofi Annan | Tubes / Valves | 261 | 10th June 2011 05:48 PM |
| An "All American" tube Project | alexmoose | Tubes / Valves | 4 | 14th July 2006 01:43 PM |
| "Improved RIAA by Jax"-Power supply help needed!!! | brigade77 | Tubes / Valves | 2 | 9th May 2006 05:04 PM |
| Scientific American : "Music's Weird Power" | eStatic | Music | 1 | 1st May 2004 03:52 AM |
| BPD-powered "American Thunder" subwoofer | BAM | Subwoofers | 0 | 30th October 2001 02:58 AM |
| Page generated in 0.08250 seconds (72.00% PHP - 28.00% MySQL) with 11 queries |
