Old 27th December 2007, 09:33 PM   #1
Default Discrete phono preamp designs?
I find myself in need of a phono preamp. I've looked around and it seems that I can find designs based on unobtainium components or designs based on opamps. Maybe I shouldn't be concerned about it, but I would like the first stage, at the least, to be discrete. Can anyone point me to designs that use readily available parts?
If not, anyone want to take a stab at designing one? Unfortunately, I'm not knowledgeable enough to do so on my own.
Whatever solution I settle on will need to work with average output moving coils (0.5 mv) and not be too expensive.
Thanks.
Old 27th December 2007, 10:07 PM   #2
cromodora's Avatar
Default Lp797
First stage at least, discrete...
LP797
LP797 supply
About LP797
P.S. maybe this thread should be moved to the 'Analogue' section.
Old 28th December 2007, 01:32 AM   #3
maxpou is offline maxpou  Canada
maxpou's Avatar
very easy to built. Maxpou
Old 30th December 2007, 08:40 AM   #4
There's Norm Thagard's design in audioXpress, Jan-Feb 2001.
JFETs: 2SK389, 2SJ109
BJTs: LS352, LS312, MPS6523, MPS6521
I thought about building this design, but decided to go with an op-amp based one (ESP) for the sake of simplicity. I haven't done the research, but if the original parts aren't available, there's probably compatible ones with higher noise specs. Or with some redesign, it should be possible to adapt the concept for all-BJTs.
I too would like a discrete phono preamp, and I think have the knowledge to adapt/design one... But I have many unfinished projects as things stand.
Old 30th December 2007, 12:16 PM   #5
jackinnj's Avatar
I simmed it and it ain't pretty.
Old 30th December 2007, 01:24 PM   #6
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
In the LP797 the hard to find duel J-fet appears to have both devices in parallel. Couldn't one just replace the pair with a single low noise J-fet and re-bias for that particular transistor?
All the trouble I've ever been in started out as fun......
Old 30th December 2007, 01:53 PM   #7
jackinnj's Avatar
Originally posted by CBS240
Hi
You can use a matched SK170 pair -- mount in close proximity -- you can epoxy them together or use a tie-rap. I believe that Linear Systems will sell small quantities of the LSK389. The pair of '170's knocks the noise down (it is already very low).
The high gain JFET's also are somewhat high capacitance...
I don't particularly like the AD797's in this application.
Here's the Maison Pacific simmed with Linear Systems model for the LSK170 -- and some changes to the capacitor values. note that the deviation in the lower chart is +- 1dB -- this is only a sim, I haven't breadboarded the device yet.
Old 1st January 2008, 11:17 PM   #8
unclejed613's Avatar
the APT/holman preamp used a discrete phono pre, designed like a discrete opamp with an interesting twist..... the diff amp consisted of a JFET at the noninverting input, and a bipolar on the noninverting input. the 2 volt DC offset caused by this mismatch was blocked by a cap(the DC wouldn't have hurt anything, since it would be blocked by the rumble filter anyway). it was an excellent low noise RIAA pre.
i have a schematic of it, but i don't have it on this machine, so i'll upload it later.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 1st January 2008, 11:53 PM   #9
Today, it would be best to stick with a fet diff pair. Fet noise is lower, today, and any advantage will be lost.
Old 2nd January 2008, 01:28 AM   #10
scott wurcer's Avatar
John is right, that design was a cute way to save short money on parts but there's no magic in the asymetric input stage. TH has definately moved on to better thing$.
I found something funny trolling around this week, the microphone modding guys think the Japanese 2SK170's are bad compared to the LSK170's. The samples of LSK170's I evaluated met or exceeded every spec on the data sheet, but I still can't figure how either would stand out from the other in an appropriate circuit.
2012, our time is running out.
Where can I get a pcb for a discrete GC preamp? raypalmer Chip Amps 2 27th January 2009 10:45 AM
which discrete preamp ? sopapo Solid State 12 13th January 2006 08:11 PM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 09:09 PM
Page generated in 0.11281 seconds (79.13% PHP - 20.87% MySQL) with 11 queries
