| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 | |
How many turns did you use ? Have you wound any transformers for Tube outputs ( Ultra linear output ?). I want to wind my own transformers and would like to know how you would wind that. Any special way to wind apart from bifilar ? I have CRGO ( cold rolled grain oriented silicon steel cores). Thanks.
AM |
#12 |
How many volts and amps did you run on the IRFP240, and..... what did it sound like???
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#13 |
I have made a lot of output transformers in the past 35 years, and I do not like the sound of push-pull pentodes, ultralinear or else. Much unnatural despite good lab testing. As it is source follower with low impedance, trafo does not need many wire turns and as such the best way is bifilar, i.e. tight coupling and wide freq. response, unfortunate I do not remember how many turns there is. I have made several different trafos and all were good. As it is not critical, I just filled available space with wires. As for core type I used ordinary mains type core material but You could use anything at hand. Grain oriented will work even better. Again it is not critical design, nothing like pentode push-pull type trannies, do not worry. I made only laboratory testing so far and would not know how it sounds. Hope to find out soon. Power supply was aprox. 20V single. I hope this was helpfull, best regs. |
#14 |
If the transformer was from mosfet source to ground and the bottom end of the secondary was grounded and *only* if the transformer has 1:1 turns ratio then you could put a 10uF to 20uF film cap from the top of the primary winding to the top of the secondary winding to make the coupling virtually perfect. some peple may think that is not necessary, but if you are only making one for yourself then every little bit helps toward making it perfect.
#15 |
Hi Cyclotron,
Yes, can do, but see what happens with ringing on capacitive load as this was the reason for transformer in the first trials with inductor + capacitor combination! On the second thought I would suspect complex phase behaviour in this combination... regards, Zelko,
| Source follower and common source output stages | slogan2112 | Pass Labs | 2 | 9th October 2008 09:19 PM |
| triple triode common cathode - only want to use 2 triodes | audiowize | Tubes / Valves | 1 | 11th September 2008 12:16 AM |
| Mu-follower vs common cathode w/- active load | jnb | Tubes / Valves | 7 | 24th June 2007 10:53 AM |
| How important is the quality of a triode used as a cathode follower | ray_moth | Tubes / Valves | 65 | 14th April 2007 12:59 AM |
| dissimilar triode for White cathode follower? | needtubes | Tubes / Valves | 6 | 11th March 2005 02:30 AM |
| Page generated in 0.08848 seconds (70.75% PHP - 29.25% MySQL) with 11 queries |
