Old 16th December 2007, 10:52 PM   #1
Badge is offline Badge  United States
Default looking for a DIY end of record lift for a manual tt
I love my Linn but somethings wonder around while it plays and forget to cue it at the end of the record. There were a couple of commercial offerings, but they seem to have gone away. Has anyone built a device to lift the arm at the end of play?
The freaks stick together, they are a tight old crew
Old 16th December 2007, 11:27 PM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Our local guy, Mandy Marino made Tonal - a tone arm lifter with auto-reset.
See pictures
Old 17th December 2007, 07:22 PM   #3
It looks like when the arm reaches the lift it trips and rotates to lift. Is that correct? Are they available to purchase? Thanks
Old 17th December 2007, 10:45 PM   #4
I sent you his email address.
Old 18th December 2007, 05:42 PM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
About thirty years ago, Monitor Audio made a rather natty little device called "Stylift". It was essentially a vertical post with a pivot sticking out horizontally about halfway up. On the pivot rotated a cylindrical vertical weight with a thin bar sticking past the pivot. The weight was rotated to be at the top (where it was unstable) and the bar rested against a stop. The idea was that the arm would gently knock the cylindrical weight and it would overbalance, the thinner bar would then swing up and collect the arm. Although it sounds bizarre, it worked very well and I successfully made a couple for higher mass arms.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th December 2007, 07:32 PM   #6
SY's Avatar
Empire made something like that, too, for their turntables. I used one- once; when the arm hit the trigger, the weight swung around the pivot, lifted the arm, and it kept going. Bounced the stylus off the label, onto the spindle, and sheared the cantilever off neat as you please.
I suspect that a silicone damped arm would be a better candidate for a device like this.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 18th December 2007, 10:40 PM   #7
EC8010, what you described seems a lot of work and freightening for the arm
SY, the lifting device I posted I so simple and effective, you should see it in action. No possibility for what you described. It's very popular here, and almost all friends I know with pivoted arms use it.
Old 18th December 2007, 10:45 PM   #8
Aengus is offline Aengus  Canada
Aengus's Avatar
I've used the Stylift without the disaster that Sy describes, but it never worked very well, possibly owing to my own ham-handedness. Positioning is very critical, at least on a Sondek, and it was either have it too close to the record's perimeter and lose the last few bars, or have it too close to the centre and have it not lift the arm. It turns out that there are enough out-of-spec records that both of these events happened too often for my liking even when the device was in the exact right spot. So I gave up on it.
I have fantasized about, but never built nor even properly designed, a lift which would use an optical sensor to trigger a (hydraulic? magnetic?) lift arm - see the drawing, which shows a plan view. Ideally, I suppose, a second optical sensor mounted towards the outside would reset the lift to its lowest point when you moved the arm back out.
Regards.
Aengus
[edit: grammar fix ...and typos ]
Old 19th December 2007, 05:21 PM   #9
EC8010's Avatar
Yes, I was aware that a lot of people didn't like the Stylift. I think it's great and I have one on my SME3009S2 and would have one on my homebrew arm except that I failed to leave room for it. It's true that ou-of-spec. records cause problems, but you can't blame that on the mechanism, more the record. John Martyn's "One World" is a case in point, with a ridiculously small recorded diameter.
Old 19th December 2007, 11:11 PM   #10
Aengus's Avatar
Agreed, not the fault of the mechanism, but frustrating nonetheless. The real issue, I suppose, is whether the geometry of one's particular table and arm allow positioning the Stylift far enough away from the arm pivot that the arm has significant lateral motion at the Stylift. Ideally suited to 12" arms, perhaps?
On looking at my previous post, even two edits were apparently insufficient. I meant to say that the drawing showed an elevation, not a plan view.
Regards.
Aengus
Motorized projector lift (scissor lift?) JRace Everything Else 5 7th January 2008 03:11 AM
TEAC x-2000r record mode stuck. Record light flashes but won't play. Any ideas? mistered05 Analogue Source 1 30th June 2005 12:51 PM
how do I lift/not lift earth frank2395 Pass Labs 30 31st May 2005 07:38 AM
Tonarm lift phn Analogue Source 10 16th February 2005 06:04 PM
Lift off LRRockBox Solid State 1 12th June 2004 06:12 PM
Page generated in 0.11910 seconds (84.90% PHP - 15.10% MySQL) with 11 queries
