Old 27th November 2007, 04:50 AM   #1
Sunsun22's Avatar
Default ASR Basis Phono Preamp
During a recent trip to Europe, I bought from a second hand audio shop an ASR Basis Phono Preamp with separate power supply. It is a non-battery version and I believe it was built in 1989 because I saw a label inside the power supply unit with 1989 on it. There are 6 RCA sockets and I think I already get the output pair but what are the other 2 paris for?
I plugged my turntable to one pair of input and there is output but the gain is not enough to drive nomrally although the sound is normal without distortion. I plugged the turntable to another input pair but all I got was hum. I have a manuel but it is in German that I don't know how to deal with the 4 dip switches inside the unit.
Does anyone has an English manuel?
Thanks regards,
Old 27th November 2007, 05:16 AM   #2
Scan the relevant page and mail it to me. I will translate it for you.
Greetings Till
Old 27th November 2007, 06:27 AM   #3
analog_sa's Avatar
The ASR units seem easy to clone. Care to take some pictures of the insides?
Old 27th November 2007, 07:17 AM   #4
Sunsun22's Avatar
Default Re: ASR Basis Phono Preamp
I believe this is a real ASR because of the workmanship and the raw materials being used. If I am going to clone, I'll clone a Basis Exclusive rather than an old Basis without battery supply.
I ran through the German manual and I "think" the two pair of inputs are for MM and MC separately. The MC channel will go through an extra gain stage while the MM will go straight to the second stage.
The MM channel should be the one that I tried with low output level because I am using a moving iron cartridge with 47K and approximately 1.2 mV output. I use the word approximately because it is a Grado Statement with original 47K and 0.75mV but retipped by Van Den Hul. After retip, I have to lower the gain of my existing phono amp (DACT) because of excessive output. Yet, this 1.2mV would not be sufficient to drive an ordinary MM phono pre resulting a low output level as described above. This is only my thoughts.
There is gain control on the MC section but the highest impedance is only 1K therefore will not match the 47K of Grado Statement. Can I change the matching resistor in the MC section to fit the Grado?
Old 27th November 2007, 07:36 AM   #5
Sunsun22's Avatar
Hi Haenisch,
Can you give me your email address to send the attachment?
My email address is gaomi2001@hotmail.com
Sunny
Old 27th November 2007, 09:57 AM   #6
analog_sa's Avatar
Default Re: Re: ASR Basis Phono Preamp
I don't doubt it's real. If you take some pics the rest of us can try to clone
Old 27th November 2007, 10:25 AM   #7
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The older Schaefer&Rumpf phono-pre models have PMI SSM2019/2142 opamps
Looks like Sponge Bob has killed another thread.
Old 27th November 2007, 11:58 AM   #8
Sunsun22's Avatar
Please find the full picture of the phono amp
Old 27th November 2007, 12:00 PM   #9
Sunsun22's Avatar
Default Close up of ASR Basis
Close up of the transistors and dip switches. I am expecting the one on the right is dip1 that takes care of impedance while the other is dip2 takes care of gain and capacitance.
Old 27th November 2007, 03:01 PM   #10
analog_sa's Avatar
Thanks Sunsun22
So, this one is all discrete. Probably paralleled symmetrical diff front end, emitter followers into a passive riaa and a simple output stage. Higher res will be essential for cloning but the design philosophy is quite interesting: not a sign of regulation, no servo. One would think these guys are allergic to ICs
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
What is the basis of this amp? Brisso57 Class D 0 18th August 2008 12:03 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Design basis for Ariels? Gaber Multi-Way 7 24th April 2002 03:08 PM
Page generated in 0.09830 seconds (87.47% PHP - 12.53% MySQL) with 11 queries
