Old 22nd November 2007, 04:11 PM   #1
kitemap is offline kitemap  United Kingdom
kitemap's Avatar
Default DIY Tonearm
Hello,
Being unspired by this, I've decided to try and attempt knocking up one myself.
I will post a progress report up here as I go along but I have a question that I need answering before I even get started with the main arm tube.
Is there any benefit to shielding the wires in the arm tube?
I will be a tube running down the centre of my dowel anyway, for ease of wiring/re-wiring and if shielding isn't an issue then it will be a thin plastic straw so I can bend it to shape. If shielding is an issue then what should it be made from?
Thank you
David
Old 22nd November 2007, 05:52 PM   #2
vinylkid58's Avatar
Based on what I've read, there doesn't seem to be any benefit from having shielded arm wires. As far as tubing goes, just use whatever works.
Looks like a nice arm. Is this going on a Lenco?
Jeff
Old 23rd November 2007, 11:01 AM   #3
kitemap's Avatar
No, for now it will be have to be on it's own plinth and used on my Pink Triangle, as I'm going for a 12" arm. I'm planning eventually to make a turntable to suit.
Here's a little piccy of the arm tube and a cross section through. It will be Walnut on each side with a 4mm strip of Ebony down the middle with a slot in for the wires.
Old 25th November 2007, 02:56 AM   #4
Nanook is offline Nanook  Canada
Nanook's Avatar
Default tonearms...
Ok, another tonearm I thought about would be the use of hickory or maple drum sticks. The bows and cello parts are cool though. The really great thing about all this is that if you use even a small amount of care, good results can be had.
Your arm idea looks very good. Wish I could actually work with wood rther than murder it (I'm feeling a little woodicide happening soon )
stew -"A sane man in an insane world appears insane."
Old 25th November 2007, 11:08 AM   #5
stoolpigeon's Avatar
If you plan on using an MC cartridge or mounting the arm on a deck with an AC motor I think it would be wise to shield the wiring.
Old 25th November 2007, 11:14 AM   #6
Nanook's Avatar
Default or....
shield the motor
Old 1st December 2007, 08:52 PM   #7
The signal leads don't need to be shielded - use twisted pairs. You could try splitting CAT5. I rebuilt an SME with an ultra-light Balsa arm which has seen about 25 years service, and embedded single thread twisted pair enamelled copper wires and it's fine. Arm mass is critical though, especially if you want to be able to track warped records.
Mike
Help ID this tonearm Jaimo Analogue Source 6 5th July 2008 06:01 AM
Another DIY Tonearm johnmarkp Analogue Source 18 18th May 2008 10:15 PM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 10:49 PM
let me see your tonearm! rbarna Analogue Source 41 16th June 2004 09:25 PM
Page generated in 0.08948 seconds (86.48% PHP - 13.52% MySQL) with 11 queries
