Old 18th November 2007, 08:34 PM   #1
Default Spacedeck 240V to 120V
I've just moved back to the US from the UK, and I'd like to get my NAS Spacedeck up and running.
The motor is a Premotec model 32311 and from the data sheet can be wired in series for 220V (which it is) or parallel for 110V (which I want). I know I'd need a new pulley too. But looking at the spec sheet from Premotec's site, the torque of the motor drops from 7mNm to 4mNm.
I figure this is a nonstarter.
Anyone have any experience with this type of thing. Or am I gonna have to give a retailer a call and buy a new USA motor/pulley unit?
thanks
Dan
Old 18th November 2007, 09:58 PM   #2
Oh and I see that at 50Hz it spins at 250rpm and at 60Hz, 300rpm. So maybe the extra gearing to get to 33 1/3 makes the lower torque acceptable. I wouldn't think that a motor would have been used that wouldn't have been usable at both EU and N.Amer specs.
I'm gonna try a dealer for a 60Hz pulley.
Dan
Old 21st November 2007, 01:44 AM   #3
d to the g's Avatar
I'm no Mark Kelly, but I'll do my best to answer your questions here.
the 300/250 rpm ratio should correlate directly with pulley radius, as should the torque on the outer edge of the pulley. Since NAS uses the minimum possible amount of torque, you may be out of luck with this particular motor. However, you can order premotec motors direct from manufacture.
Old 10th December 2007, 02:41 AM   #4
Figure if it can turn it at 45rpm with the torque from 240v hookup, it can turn it at 33rpm wired for 120V
Dan
120v/240v amplifiers dsiroky Solid State 1 25th September 2008 11:58 AM
Two 120V transformers in series for 240V ? Bernhard Power Supplies 8 22nd November 2005 12:28 AM
amp 120v-240v conversion chrish Solid State 10 12th December 2004 09:49 AM
toroid rewiring from 240v to 120v pjb Parts 3 22nd February 2004 01:28 PM
Using 120V transformers with 240V supply Peter Daniel Solid State 12 21st January 2003 12:32 AM
Page generated in 0.08976 seconds (73.24% PHP - 26.76% MySQL) with 11 queries
