Old 1st March 2008, 04:09 AM   #11
KP11520 is offline KP11520  United States
KP11520's Avatar
The eBay reseller selling the Unity Audio headshell leads (Oz Enterprises) has no more and couldn't deliver. Back to square one again or spend too much! Yikes!
This shouldn't have to be so painful.
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Old 9th March 2008, 06:38 PM   #12
Panicos K's Avatar
Why don't you solder your headshell wires directly on the headshell pins and cover the joints with some shrinkable sleeves?
Old 9th March 2008, 10:37 PM   #13
kevinkr is online now kevinkr  United States
kevinkr's Avatar
Probably a good way to ruin most headshells out there which seem to have a plastic insert that melts by the time you have even managed to tin the pins. (I tried this once and was then forever plagued with intermittent connections only resolved when I replaced the entire headshell.)
www.kta-hifi.net
Old 9th March 2008, 10:42 PM   #14
Panicos K's Avatar
I have done it in some of my headshells without any problem.In the less than two seconds time you need to do it,no problem,even with headshells with plastic inserts.Many have teflon inserts.You just need to be careful and quick.
Old 12th March 2008, 07:47 PM   #15
Bouquet is offline Bouquet  Netherlands
Freeze the plastic insert of the shell with cold=spray and solder as quick as possible.
At the cartridge side , you can use the connector bushings of a female D-connector.
regards
Bouquet
WTB headshell, Yamaha PX-3/PX-2 pfcs49 Swap Meet 0 24th January 2009 03:37 PM
Grace G-707 headshell Gram Analogue Source 14 27th July 2008 08:16 AM
Technics Headshell Socket/Tonearm Rewire KP11520 Analogue Source 2 24th March 2008 07:14 PM
New Headshell -- too light GhettoSQ Analogue Source 3 28th July 2006 09:57 PM
attaching a headshell spooky1234 Analogue Source 4 23rd March 2005 03:07 PM
Page generated in 0.08681 seconds (71.46% PHP - 28.54% MySQL) with 10 queries
