| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I have an Infinity Black Widow (the original aluminum tube version) tonearm I'm considering re-wiring, BUT I'm not sure how to remove/install the wiring.
The original wires are very small gauge, stranded, and cloth wrapped. They're routed through the very small diameter arm body. Removing the DIN connector from the arm pillar is easy enough, it's secured with a set screw, but pulling gently at either end of the wiring doesn't seem to allow movement. Does anyone know how to approach re-wiring this arm? Has anyone taken one apart - and then successfully put one back together? Thanks. - SJ |
#2 |
Talk to this guy. He is in NJ. He might be a good place to start. He does Tonearm rewiring and he knows the Gotchas! www.kabusa.com/ Good Luck! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#3 |
Hi TVR255m
Let me know if you succeeded, I just buy a black widow with defective wiring :-( thanks |
| Black Widow info here... | Russellc | Analogue Source | 5 | 5th November 2008 08:29 PM |
| NEED HELP on my Kenwood KD-500 and the Infinity Black Widow Tone Arm | EJCUSA1 | Analogue Source | 3 | 22nd May 2004 06:21 PM |
| Kenwood KD-500 and the Black Widow NEED HELP | EJCUSA1 | Analogue Source | 4 | 21st May 2004 05:09 PM |
| Infinity Black Widow | mavz | Analogue Source | 7 | 13th February 2004 01:31 AM |
| Black Widow tonearm setup | FrankW | Analogue Source | 3 | 13th January 2004 10:33 PM |
