Troubleshooting Rega Planar 3
Old 17th September 2007, 10:13 PM   #11
d to the g is offline d to the g  United States
d to the g's Avatar
Originally posted by woodturner-fran
O-rings on the fingerlift...??
I haven't heard that one before - what differences did you hear with the rings on/off?
Certainly beats taking the fingerlift off.
Old 18th September 2007, 04:15 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by chrisb
In my own case, a local designer/guru developed an underslung design from a combination of Delrin & brass.
This one would be pretty easy to diy...
dave
Old 12th November 2007, 02:15 PM   #13
whitelabrat is offline whitelabrat  United States
whitelabrat's Avatar
Lot's of good info here.
I believe I've figured out my problem. I was listening to a record the other day when I noticed my subwoofer wasn't doing anything. I pulled the left channel plug from it and BOOM. I got my multimeter and discovered the hot and ground plugs were reversed on one channel of the cartridge. <Slap hand on forhead>.
The imaging is correct, the bass is there, and much less hum. I just never thought the previous owner would have wired it up wrong.
Just a listening note. This turntable sounds much better than anything else I have including my cheapo SACD player!
Old 12th November 2007, 04:17 PM   #14
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Troubleshooting Rega Planar 3
surely o-rings on the fingerlift just increases the weight that can be excited into vibration...
Paradise Pre-reg PSU PCBs
Troubleshooting Rega Planar 3Hide this!Advertise here!
Rega Planar 3 question about oil bart_dood Analogue Source 25 8th February 2011 09:28 PM
Rega Planar 3 PSU resistor kimmo Analogue Source 8 3rd March 2008 11:23 AM
Rega Planar 3 owners Sarchi Analogue Source 6 19th May 2006 03:44 AM
Rega Planar 2 Bearing Redart Analogue Source 1 9th April 2006 09:19 AM
Rega Planar with Marble Top ???? LuvPioneer Analogue Source 4 26th April 2004 05:43 PM
