| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
in the urge to build something useful with parts I already have in my bin, I sketched a phono input stage tonight. I build the attached circuit, input stage is biased with 6mA (IDSS 7.5), the FC-Fets are around 11mA, the most juicy I have. I can't do distortion measurements, a square looks fine up to 70kHz, gain is plenty. The working conditions for the FET's need refinement (wish I had some more V-grade parts) PSU Voltage seems a bit low as well. The input offset is around 4mV, which is a bit high for my liking, so no listening tests so far (I even havent a second riaa stage handy...) Should be no problem to change it for non-inv input, however. My reasoning was: -Push-Pull enhances linearity -No Diffamp helps noise -Since MC-Carts are low on voltage and relativly juicy on current, Folded Cascode might present mostly it's sonic advantages here. - haven't seen this topo for a phonopre here. So, what do you think, is this a worthwhile approach? Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#2 |
Won't R7 and R8 cause a loss of S/N since they're essentially in series between the cartridge and the FET inputs?
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin |
#3 | |
But then, 4mV Offset with Zout of 50R gives 0.08mA, which seems too high for a poor MC-Cart, doesn't it? Rüdiger
#4 |
I built the same topology with (medium) power transistors that are constructed with many parallel sections, good for low noise. I used a capacitor in the position of R5 in your figure. That capacitor made a huge difference in sound, depending on the type and value. Worth playing with it.
#5 | |
If you apply the input to the gates it's pretty much identical to a Vendetta. And it solves the offset issue without having to match hundreds of fets. |
#6 |
As far as I know, the vendetta is differentialvendetta
And yes, if I can't make it run, I have to use the gates. Since I have good results in the phonnoclone with the inv. input, and the famous hiraga le prepre is using emitter input, I thought this might work better (at least with a middle to low impedance Cart with flat Frequency over impedance plot. Just wish there were such plots...) Rüdiger
#7 | |
Yes, I probably will parallel some FET's in the front end later. Do you mean you *replace* R5 with a cap? I can't see how the thing could be working then? Rüdiger
#8 | |
#9 |
Hm, ok, at least I know now it will work cool!
Thanks, Rüdiger
#10 |
is there a way to vary the models of the FET's in LTSpice?
I get substantial differences in sim and reality looking at DC-operating points. Rüdiger
| Adding a third input to a differential input stage? | maudio | Solid State | 15 | 11th October 2006 02:16 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| input cap at D1 I/U stage | Klaus | Pass Labs | 3 | 30th December 2003 11:00 AM |
| Input stage | Andrey | Solid State | 5 | 21st June 2002 01:32 PM |
| Page generated in 0.13057 seconds (77.76% PHP - 22.24% MySQL) with 11 queries |
