| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Here is a picture of a layered plinth I made for a friend of mine. It is made up of random layers of Baltic birch plywood, solid basswood, and aluminum. It is covered with 1/8" wenge veneer.
John |
#2 |
I sorry, for some reason the photo won't load. I'll try again later.
John |
#3 |
O.K., the pictures of the plinth I built for my friend Albert Porter are now up on this website:
http://www.soundfountain.com/amb/sp10plinth.html It can also be seen here: http://cgim.audiogon.com/i/vs/i/f/1193606055.jpg A very interesting project with a surprisingly good result. John |
#4 |
Very nice work.
#5 |
Thanks! The salient feature of that plinth is the grey cast iron block which is coupled by a brass rod to the bottom bearing of the motor and acts as vibration sink. The result was an amazingly quiet turntable - actually more quiet and with blacker backgrounds than the Walker Proscineum. Not at all what we expected.
John |
#6 | |
#7 |
Any electric motor produces some noise, and a direct drive turntable motor is coupled directly to the platter and is not isolated from the rest of the 'table. The moving coil cartridges used have outputs on the order of 200-600 microvolts, so noise is obviously an issue. The grey cast iron block has a very high specific damping factor (highest among commonly available materials) and the brass rod makes a convenient transfer path for noise and vibration to the iron block, where they magically disappear. This base is admittingly a brute-force solution to the problem, but it worked very well.
John |
#8 |
DUH! Of course, direct drive!
I guess my brain wasn't awake yet, this morning....
#9 |
I kind of had a feeling that you hadn't realized that this was a direct drive application.
#10 | |
DIY !
"What HiFi" + other reviewers did measurements of niose/rumble++, and found it better than most high-end belt-drives (of it's time)... Arne K
Ars longa, vita brevis |
| CNC Cut Layered Speaker Kits | GraemeC | Full Range | 32 | 13th March 2009 07:20 AM |
| Thorens 124 Plinth | Tee-Rex | Analogue Source | 8 | 1st March 2008 01:37 PM |
| A new plinth for an old turntable... | simeon_noir | Analogue Source | 8 | 6th November 2007 08:38 AM |
| Layered/laminated plywood | dublin78 | Multi-Way | 31 | 2nd November 2007 04:57 PM |
| Page generated in 0.10925 seconds (72.39% PHP - 27.61% MySQL) with 11 queries |
