Old 2nd September 2007, 11:42 PM   #11
anatech is offline anatech  Canada
anatech's Avatar
Hi MadMutt,
See all that dark brown "glue"? Remove it. It can go conductive and corrosive.
Guess that means the vfl is shot.
No, not unless the filament is open. Check for your voltages (compare). Check the display uP is running (need 'scope). It might be fine once you clean it up.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 3rd September 2007, 12:22 AM   #12
MadMutt is offline MadMutt  Australia
Only gorilla snot I see is on the back of the display board. (cable anchoring)
I shall remove it.
Will post back when done and tried.
Any idea which pins on the display are the heaters ?
Wondering if I can check the actual display.
Only hiccup is that the two ST-7's I have are ever so slightly different in wiring.
Good display in bad unit = good.
Bad display in good unit = bad.
So the fault follows the board.
Might even swap the main i.c over as an acid test.
If I get crazy I could even swap the vfd over, but I'm hesitant as I don't want to damage the good one.
Oh, I do have a scope too.
Old 3rd September 2007, 12:38 AM   #13
anatech's Avatar
Hi MadMutt,
The two pins on the outside are generally the filaments. Often two are shorted together on each end, look at the leads. If you unplug the board, compare the resistance between those two points on both boards.
-Chris
Old 3rd September 2007, 01:05 AM   #14
Compare with other board.
Yes.
I'm obviously having a 'blonde' day.
So obvious yet . . . . . .
Old 3rd September 2007, 01:10 AM   #15
anatech's Avatar
Believe me, we all do!
Swiss Physics 6A repair info Cole Johnson Solid State 2 5th October 2010 07:42 PM
Repair scatches on Plexigalss or lexan - Info HeavyD'sCustom Car Audio 8 15th May 2009 05:41 PM
Sony dat REPAIR INFO superdave058 Digital Source 3 5th May 2007 07:52 AM
Circuits / Info on Tracking Notch Filters JohnW Solid State 3 6th July 2004 01:55 PM
Page generated in 0.07614 seconds (72.19% PHP - 27.81% MySQL) with 11 queries
