| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Hi Paul,
Very interesting, thanks for your reply. I think I come closer and closer to a solution. I bought the freestanding single TT for a good price at the Salvation Army Secondhand Shop for 10$, it was a good deal for me and my money went to something useful. The TT has two connectors at the rear, one with 5 pins and one with two. Additionally I see a shielded AF cable with phono plugs coming out at the backside, for audio I am sure. I want to make a power supply and probably some controls if needed, and hope that I can get a hint about how to connect these two connectors. I have opened the bottom lid and see that the 5 pin connector has two cables connected to it, a 3 core cable and a 2 core cable. Maybe the 3 core cable is for power supply 10+10VAC? I can dismantle the printboard but I am intensionally careful. A schematics had solved the problem but service documentation of such equipment seems rare at internet. Thanks again, Paul, from Anton. |
#12 |
Anton
I'm glad I can help. You assumed correctly, the 3 wires going from the 5 pin connector to the PCB ( near the 2 large electrolytic capacitors ) are for power supply , just be careful to connect the correct one ( white in my case ) to the center tap of the tranformer. Paul |
#13 |
I forgot something: the PS-LX10 is part of the system LBT-V10 for witch seem to be service manuals on the web ( for a price of course, but unfortunately for me acquiring a manual from www is not a option )
#14 |
I hate to drag up an old thread, but I recently acquired a PS-LX10 turntable in the same condition as yours. I was wondering if you could elaborate a little more on the power supply you used to get this thing working. In the post you say you used a "2x10 V transformer" but I'm not exactly sure what you mean. I'd really appreciate any insight you or anyone else can give into this.
Thanks |
#15 |
Hi odsquad64,
if your TT doesn't have a transformer in the case ( mine didn't , but there is a space witch seems to suit one ) you need a mains transformer with two secondary windings with 10volts each or a center tapped 20 volts secondary ( the TT uses a split power supply , the rectifier bridge and the smoothing caps are on the main pcb ) , just make sure you connect the transformer right . I used a fairly small transformer ( 20watts - i don't think the original one was much larger -judging by the space reserved for it in the case ). If you have further questions I will be happy to help. Paul |
#16 |
Thanks, hopefully I'll be able to get this thing running pretty soon. Now that I know what I need I've just got to find it. I appreciate you clearing that up for me.
#17 |
Hey guys,
i just found this Thread on Google. Since i have an old PS-LX10 too, i just registered here. As raindog said, there is Documentation about the LBT-V10 on the internet. I've found a "Service Manual" for the LBT-V10: LBT-V10 service manual download for SONY Stereo fix technical repair instruction schematic diagram free : GiveMeFile.Net It does not contain specific information about the PS-LX10, since it is an optional part, but it has a general overview about the connectors on page 8. There you can see, that the 3 pin cable is a connection between the Turntable and the cassette deck, obviously used for synchronizing. The 5 pin cable has only a description for 2 of the 5 pins. one is "STOP" and the other "PS FUNCTION". the cable with the cinch plugs is Phono output. Hope i could actually help you a bit. i will now try to repair my own PS-LX10. thank you for the tips with the mains connection Greetings, stewe |
#18 |
I've done an important improvement to my "craptastic" TT : an Audio-Tehnica AT91 cartridge ( huge improvement in sound quality ). I had to do minor modifications to the head-shell ( a bit of filing and a hole in the top for the screw holding the cartridge in place ) an this time I took pictures !
| Page generated in 0.10090 seconds (76.39% PHP - 23.61% MySQL) with 10 queries |
