Old 24th August 2007, 12:26 AM   #11
Yep.
What I need to do is pull out the rack ( ) unplug everything and then add them back in one by one and see what I get.
What a right royal PITA.
Fran
Old 24th August 2007, 12:28 AM   #12
SY's Avatar
If the hum is 100Hz, then Arnold is right, you've got to get your preamp in order. Does the hum go away when the cables are disconnected from the input? If you put shorting plugs on the input, is there still hum?
Assuming "yes" and "no," you really are picking up hum externally. As to your preamp...
...you need either a balanced preamp or an input transformer (I use the latter).
If the preamp hums with open or shorted inputs, you've got to clean up its grounding. Grounding is ultra-critical for low-level circuits with lots of bass boost.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 24th August 2007, 01:27 AM   #13
Ok,
disconnecting even one of the input cables into the phonostage makes the hum dissappear. I think the hum is 50Hz (my mains frequency) but being new at this means I'm not 100% sure.
I think I'll investigate the whole grounding in my system. Perhaps theres some kind of ground loop between components thats somehow being magnified by the high gain of the phonostage and thats why I'm seeing it there.
Really annoying this is!
Fran
Old 24th August 2007, 03:08 AM   #14
SY's Avatar
Classic hum loop, which is nice because the fixes are well-known. Going balanced is the surest, highest performance, and most difficult way. Does that preamp use an input transformer? If so, balanced will be easy.
Do you have your arm grounded to the turntable and the turntable ground connected to the preamp chassis?
Old 25th August 2007, 02:00 PM   #15
OK the good news: this problem is sorted. Yes SY it was a hum loop - got it sorted out - and I'll post some details over in the Phonoclone thread soon.
As for input transformer - SY, have you got a glass of malt in your hand? Are you sitting down...
Its a SS amp using opamps...
Please forgive me for straying form the true path of tubes...
yours (humbly bowing)
Fran
Old 25th August 2007, 02:24 PM   #16
SY's Avatar
He weighs the same as a duck! He's a witch! Burn him!
Old 25th August 2007, 03:31 PM   #17
tell you what - it must be some duck - supply a cities worth of chinese restaurants that duck would!!!
fran
Old 26th August 2007, 08:25 AM   #18
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Glad the problem has been solved.
I'm currently auditioning a Tango phono stage from Acoustic Signature, and this one is good!
It does not need a ground wire when used with my Clearaudio 'table, but requires one when use my JVC or Technics.
Anyone using microphone cable in making their phono cable? rich121 Analog Line Level 8 10th September 2010 12:50 AM
Recommend a good phono cable for my project Dogpile Analogue Source 3 8th October 2006 11:56 PM
replacing phono cable kazoo Analogue Source 1 20th June 2005 08:22 PM
MC phono cable questions (Long) phn Analogue Source 6 26th December 2004 06:22 PM
DIY phono cable suggestions. gurevise Analogue Source 33 22nd December 2003 12:19 PM
Page generated in 0.09080 seconds (76.58% PHP - 23.42% MySQL) with 10 queries
