| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
The display of the tuner doesn't display any more.
I measure about 14 V DC on the pins of the display. As the tuner only has DC voltage levels of up to 18 V I suppose the supply voltage to the pins is all right. Anyone experience with this problem? Perhaps anyone with a service manual? Thanks for you reply. |
#2 |
I know older displays had that little light bulb behind them.
Not knowing the 4150, I can't tell if that would be your problem. I recall an AKAi video with the same problem. Somewhere in the power supply, close to the display, one had to change a few capacitors. That's about all I can tell without schematic. /Hugo |
#3 |
The display runs at 3.2V from a seperate winding on the transformer, this winding also runs the light above the power switch.
In the attached partial schematic, the relevant lines I have highlighted in red. Hope this helps Regards James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson |
#4 |
This is where they connect to the display
#5 |
Hi TVI
Great! It certainly helps. One of the supply pins didn't connect well. I resoldered and the display gave light! The voltage across pins 1 and 36 is 3.04 V AC. I can now see what frequency I tune to. The display is however still rather dim. 2 elements light at a proper level, all the others are dim (I can see it when the tuner is searching). What should I measure on the other pins? |
#6 |
I found the cause of the problem:
Besides a bad contact the voltage was too low. I raised it to 3.5 V by putting a resistor in parallel to the one in the schematic. Thanks a lot Dick. |
#7 |
I have a simillar problem with my tuner.
Onkyo 9090 II , the display is dim , I could use some help Thank you |
#8 |
Hope this helps
Regards James
#9 |
And this
Regards James
#10 |
Thank you James.
I have the original service manual for the 9090 II , do you think its the same problem ( contact on display pins ) I was thinking maybe due to age of the tuner its time to replace all the elec. capacitors , but i will inspect the pins first |
| Onkyo help !! | large | Solid State | 0 | 29th January 2009 01:24 PM |
| Larsholt fm tuner front end for JLH tuner design-Any still available? | djsb | Analogue Source | 0 | 25th December 2008 04:46 PM |
| NAD 4150 problem/parts | ericrhenry | Parts | 0 | 27th February 2005 08:48 PM |
| FM tuner, Onkyo T-4500 is reviewed | 3moons | Analogue Source | 2 | 14th July 2004 04:16 AM |
| Looking for Onkyo A-7 or A-10 | mjarve | Swap Meet | 0 | 29th April 2004 04:07 AM |
| Page generated in 0.12114 seconds (79.13% PHP - 20.87% MySQL) with 11 queries |
