Old 13th August 2007, 05:14 PM   #11
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
Originally posted by PMA
Distortion at 1V, 10kHz (simulated).
Yes, 0.01% is possible for a good combination of values
What was the gain in this case?
Cheers
Alex
Old 13th August 2007, 05:20 PM   #12
PMA is offline PMA  Europe
PMA's Avatar
Hi Alex,
The gain was 9 dB.
Pavel
Old 13th August 2007, 07:28 PM   #13
x-pro's Avatar
Hi Alex,
The gain was 9 dB.
Pavel
Hi Pavel,
here is a result of my simulation with 3 transistors and local NFB only for 9 dB gain and 1V RMS output (somewhat different circuit )
Cheers
Alex
Old 13th August 2007, 09:32 PM   #14
PMA's Avatar
Hi Alex,
excellent!
(somewhat different circuit, as you have said )
P.S.: anyway, your 3rd harm. is higher than mine ...
Old 13th August 2007, 10:28 PM   #15
x-pro's Avatar
Hi Alex,
excellent!
Pavel, in any case we can not compete to the circuit I attach here, by Michael Kulish from Russia. I made two simulations, one with and one without an output follower, both under the same conditions - 10 kHz, 1 V RMS output, 9dB gain. It is an excellent application of an error-correction way of linearization in a very simple circuit. It works in real life too .
Cheers
Alex
Old 14th August 2007, 03:00 AM   #16
anatech is offline anatech  Canada
anatech's Avatar
Hi Alex,
Try to simulate a real world load on your outputs and rerun the sims please. I always find unloaded measurements much more promising than loaded ones. Some circuits are much better than others in this respect.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 14th August 2007, 06:46 AM   #17
PMA's Avatar
Originally posted by x-pro
Hi Pavel,
Cheers
Alex
Hi Alex,
though it is maybe not apparent, as the component values are missing, the circuit I posted had also local NFB only. Gain is completely defined by R6/R3 (with respect to hFE, off course). R10 is very low in value and can be omitted completely. R4 is just biasing resistor and its value is like 10M. Input impedance is quite high (about 1M) and R4/R10 do not constitute global feedback.
Pavel
Old 14th August 2007, 06:49 AM   #18
PMA's Avatar
Cheers
Alex
Looks very interesting
Old 14th August 2007, 07:21 AM   #19
PMA's Avatar
Hi Alex,
hereby what I got from the Kulish circuit. No follower and no load. Excellent result, however.
P.S.: I have to add that this is for source impedance of 1k. Distortion very quickly rises with Zout of the signal source. This is very very different from my circuit, which yields quite same distortion even for 100k source impedance.
Old 14th August 2007, 09:12 AM   #20
x-pro's Avatar
Originally posted by anatech
Hi Alex,
-Chris
The distortion of this circuit is load-independant without the output buffer, only the gain will change if you connect load (with a coupling capacitor) to the (out2) of the second (unbuffered) circuit.
I've just copied the values from the original article. Transistors here are run with high currents so the input impedance is fairly low. You may increase the resistor values and reduce that effect thought 10K distortion would rise a bit. Also this is an error-correcting circuit and as such requires balancing of the correction - as you may see I had to adjust one of the values to partially compensate for the buffer distortion. In the same way it is (I think) possible to compensate some of the imbalance due to the source impedance if it is constant.
Cheers
Alex
PCB for simple OP-preamp kmj Chip Amps 8 8th August 2005 09:10 PM
simple preamp pxr5 Solid State 9 20th November 2004 07:29 PM
Simple discrete preamp OliverD Solid State 69 22nd July 2004 10:14 PM
Very Simple Preamp Christian Solid State 1 21st March 2002 09:50 PM
need simple preamp JoeBob Solid State 41 9th January 2002 06:06 AM
Page generated in 0.14122 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
