| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi all:
Just thought you might like to have a look at YATP (Yet-Another-Turntable-Project). This one is the product of about a year's thinking and one frenzied weekend of drawing, cutting, gluing, screwing, etc. Platter is solid cast brass, shaft is stainless,, bearing housing is aluminum with brass sleve and hard steel ball. Motor is a/c synchronous. all of the above robbed from an old Unity Rotary Platform. Plinth is one layer 1/2" HDF (high-density-fiberboard) and 3/4" laminated Pine, with a spine of 1/8" aluminum embedded between. The spine was glued in place in the cavity with PL-400 construction adhesive (the stuff used for gluing floors to joists in house construction) and the HDF/Pine glued together using the same adhresive. As you can see, the plinth has no finish at this point, but the table will get torn down this weekend and coated with clear marine epoxy. This will form another conatrained layer, for a total of 4. The arm is a Syrinx, completely rebuilt and re-wired with 0.5mm OFC copper, continuous from cartridge tags to phono plugs. I used 3/16" teflon fuel line tubing for the cable body, with the wire twisted inside. The arm is carrying a DL103D. All in all, it sounds MUCH better that my ancient Ariston RB11/Grace 707. The bass is solid and the mids & highs have much more definition and detail. I will post another pix when the plinth is finished. I think it will look nice and I am very happy with the sonic improvement in my system. Jess |
#2 |
Nice work Jess, not surprised it sounds better than your old Ariston. Love the brass platter too, must have been fun to turn that. Are you using a sub-platter and belt drive?
Jeff |
#3 |
As stated the platter was donated by an old Unity, so I got it pretty much as you see it. Good Thng too, 'cause there's no way I could have cast or machined it.
Yep, it is belt drive. The platter has an inner face for the drive (like most Japanese belt- drive tables) about one-half of the diameter of the outside and the motor is under the rear left of the platter. ![]() Jess |
#4 |
PS: Jeff - if you are coming to the 'Fest at Daves on July 28th, you will probably see it, 'cause I plan to bring it.
#5 | |
Jeff |
#6 |
jesse, beautifull table. I am so jealous of those that actually have some Skil ...ooops, that was for Chris, elsewhere.
beautifull table. Jeff hoping to make it out there. Anything I could bring to Daves? A t-amp, or phono stage or? Someone let me know.... stew
stew ☮ -"A sane man in an insane world appears insane." |
#7 |
Nicely done Jesse.
#8 |
It looks beautiful. What are the legs made of? How heavy is the platter, is it hollow inside?
Marek |
#9 | ||||
from Vinyl-Addict:
from markest: Quote:
![]() Quote:
I found three suitable springs from my junk bin (no idea where they came from) and epoxied a furniture nut (1/4" NC thread) into one end of each spring, doing my best to have them set square to the centerline of the spring. Lastly, I wrapped the spring(s) in thick (1/4") felt and pushed them into the PVC 'cups'. Quote:
Jess |
#10 |
As soon as I saw it I said out loud, "Ooh! ooh!!"
Great stuff!
People in audio whom I admire.... Henry Kloss, Edgar Villchur, John Dahlquist, Bowers and Wilkins, Theil and Small, Don Keele, our own Nelson Pass. In short VISIONARIES. |
| FS jvc turntable | woody | Swap Meet | 2 | 1st May 2008 07:13 PM |
| My DIY turntable. | harwoodspark | Analogue Source | 21 | 27th April 2008 08:40 PM |
| JVC D.D. turntable | gain-wire | Analogue Source | 0 | 12th November 2006 06:25 PM |
| My UcD adventure | justcallmefrank | Class D | 71 | 17th June 2006 02:27 AM |
| Turntable Hum | Delboy | Analogue Source | 7 | 10th June 2003 10:02 PM |
| Page generated in 0.20966 seconds (47.90% PHP - 52.10% MySQL) with 11 queries |
