Thorens TD 125 speed problems
Old 20th June 2007, 11:04 AM   #1
singinghairdo is offline singinghairdo  United Kingdom
Unhappy Thorens TD 125 speed problems
Hello.
I realize the Thorens TD 125 mkII is known for having a pitch control that wears out. Mine has and I'm desperate to fix. 33 rpm is fine, but 45 runs consistently too fast. Does anyone know how I can fix this problem please. I imagine a change of the electronics controlling the pitch?
Old 20th June 2007, 12:14 PM   #2
Mark Kelly is offline Mark Kelly  Australia
Check R22
Old 20th June 2007, 12:17 PM   #3
Default R22
Sorry, new here, what's R22, or is that a component?
Old 20th June 2007, 10:33 PM   #4
R22 is the variable resistor controlling the frequency of the Wien bridge in the motor controller for 45 RPM. It is the most likely cause of the symptoms you describe.
Old 21st June 2007, 07:28 AM   #5
Cool thanks. So a replacement resistor should do it?
Old 21st June 2007, 01:59 PM   #6
John Caswell is offline John Caswell  United Kingdom
Default TD125 speed
Hi singing
What I suggest you do is initially mark the positions on to the PCB of all the variable resistor wipers with something indelible, then give them all a squirt of IPA and wind the controls back and forth to clean the tracks and wipers or scrub them with a small stencil brush. Let them dry off, then set all the wipers to their marked positions and you should be very near to the original settings and speeds.
John Caswell
Old 21st June 2007, 06:34 PM   #7
Default Thanks
Thanks John,
That's most useful - I'll let you know how this goes...
Ed.
Old 25th June 2007, 11:24 AM   #8
Thumbs up Thanks
Hi John,
As promised some feed back on your advice. The IPA spray, plus some action with a tooth brush worked a treat. 1st time it didn't work so well, so I did it again and re-cleaned. Speed goyt much more stable. I then fine tuned the position of the wipers by moving them very slightly (clock wise and anti clockwise) from underneath the deck and checking to see what affect this had on the speed and pitch control. Some crazy results if you over-do it...
Very happy with the results, thanks for you advice.
Ed.
Old 25th June 2007, 01:07 PM   #9
Default Thorens TD125
Hi Ed,
Well done! Ideally you need a scope and DMM to sort it properly but if it is just dirty controls then this quick and dirty fix often works very well
John
Old 25th June 2007, 01:24 PM   #10
Learning as I go... I realise the tooth brush was a little bit crude!
I have heard rumours that the 16 rpm setting can be tweaked to run at 78 RPM, is this true, or ill advised?
Thorens TD 125 speed problemsHide this!Advertise here!
Technics SP 10 Speed Problems rollinr Analogue Source 29 27th October 2017 09:05 AM
thorens td 180 in ....high speed east electronics Analogue Source 0 7th October 2008 08:29 PM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 10:05 PM
Thorens TD 125MKII speed inconsistent? 600LPs Analogue Source 0 26th October 2007 05:32 PM
