Thorens TD 125 speed problems - Page 2 - diyAudio
Old 25th June 2007, 08:26 PM   #11
Default TD125 speed
Hi Ed,
The toothbrush idea is perfect, I use them for the same thing also stencil brushes for cleaning PCBs with IPA .
I don't know about tweaking it for 78RPm, when I next get one in for repair I will have a look
John
Old 25th June 2007, 11:16 PM   #12
Thanks John
Ed
Old 26th June 2007, 02:50 AM   #13
Originally posted by singinghairdo
I have heard rumours that the 16 rpm setting can be tweaked to run at 78 RPM, is this true, or ill advised?
The frequency of the Wien bridge can easily be changed - try changing R18 to around 22k, R19 to around 10k and C11 to around 0.47 uF. Whether you can develop enough voltage to run the motor at 78 rpm and how it copes with this I don't know.
Old 27th June 2007, 05:41 PM   #14
kevinkr's Avatar
You'll also need to replace the 250uF phase shifting capacitor normally used for 16rpm with something like 33uF + 10uF in parallel to get the right phase shift on the motor winding.
Set the voltage to 8Vrms as per 45rpm operation or more if adjustment range is sufficient.
I can't say whether or not any of this is a good idea, and possible problems with the power amplifier and motor could ensue. Use at own risk!
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th June 2007, 12:43 AM   #15
Thanks Kevin, I'd overlooked the need to change the phase shift capacitance.
Old 27th October 2007, 12:26 PM   #16
600LPs is offline 600LPs  Thailand
Using a KAB Speedstrobe, I'm noticing an apparent drift in speed with my TD 125 MKII. It's also hard to get the speed right in the first place, as if the speed control seems to be sticking and letting go (so fine tuning is more of a slingshot operation! ). ;-)
I've also noticed that after I get the speed apparently right, and record (to digital) an album or two, the speed seems to have changed - test is always without a record or other weight on the platter.
I'm learning about stylus drag, etc., but I didn't think such a thing was an issue with my MkII's 16 pole motor. Ah, learning curves.
I'm following up on this thread to ask:
1. What can I do about an apparently unresponsive speed control - clean, replace?
2. Is a motor problem causing drift? If not, what's the most likely cause?
I've been using a KAB Speedstrobe for a while now, but only recently noticed problems with setting and keeping the speed.
I've changed arms on my table, but I don't do well with soldering, etc., so advice on the practicality of fix attempts vs turn table replacement would be appreciated. What's a good choice if necessary, when considering the cost on 500 recording sessions or so.
Old 27th October 2007, 04:04 PM   #17
ashok's Avatar
Default Service manual
Service manual downloadable from here :
http://www.vinylengine.com/library_m...ed_model=TD125
AM
Old 27th October 2007, 05:49 PM   #18
ashok, thanks for your reply and the link.
My TT is the TD125 MK II, though, and I couldn't find it there.
Old 28th October 2007, 03:04 AM   #19
ashok's Avatar
How could you miss it ?
It's listed at the bottom of the Downloads list as " mkII service manual (en) "
Cheers.
AM
Old 28th October 2007, 01:25 PM   #20
Default TD125 speed change
Hi 600
I think the first thing you should do is either clean with IPA or replace the speed adjustment pots on the motor drive board. The main problem appears to be the silver wiper track becomes black with Silver Sulphide so cleaning it with IPA and putting a very light smear of silicone grease on them will help.
If you mark the position of the wipers with an indelible pen, as I have said before, it is pretty easy to get back to square one.
To set the Wein bridge pots you really need a 'scope to look at the waveform.
John Caswell
thorens td 180 in ....high speed east electronics Analogue Source 0 7th October 2008 09:29 PM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 11:05 PM
Thorens TD 125MKII speed inconsistent? 600LPs Analogue Source 0 26th October 2007 06:32 PM
Technics SP 10 Speed Problems rollinr Analogue Source 26 21st June 2004 07:44 AM
Copyright 1999-2017 diyAudio
