| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi all,
I got this information from the service department of our Rega supplier and thought I would pass it on. It should prove useful to anyone looking to do some DIY maintenance work. For cleaning hub/bearing assembly and lift/lower assemblies Solvent cleaner containing 1.1.1 available from RS components For lubricating hub/bearing assembly Comma Hypoid EP80, Castrol EPX 80w/90 & Shell Spirax EP90 are all well recommended. For lubricating motor Motor Oil (Hypergrade or good multigrade) For lubricating RB300 & RB250 lift/lower assembly Kilopoise grease (available from Rega) For lubricating R200 lift/lower assembly Silicone grease (available from Rega) For re-glueing pulley onto motor spindle Loctite 496 cynoacrylate glue (5gm bottle available from Rega) Cheers, Neill |
#2 |
Hi Neil thanks for the info.How do you actually lubricate the motor for the Rega? Are you doing an all-out job here? I am interested in any tips you might have.
#3 |
Im aiming to get a p3 service manual when I next speek to our Rega supplier, ill post and let you know if i can get my hands on a copy.
#4 |
That'll be GREAT!.. I look forward to having a copy of it for personal reference.
#5 |
Any idea if this is true for the P1 as well? It has a weird flat bearing instead of a captive ball.
I ask since I needed to replace the subplatter due to a warped spindle, and am using some Thorens oil till I can figure out exactly what should go in there. it sounds great now but drags and I assume this is due to too high viscosity.
GhettoSQ Somewhere between Craft and Kraft |
#6 |
GhettoSQ: Despite the bearing being different I would be very surprised if they used anything other than Comma Hypoid EP80 or similar.
coolmaster: No promises, but ill do my best. |
#7 |
thanks!
#8 |
The above lube types IS current and official.
#9 |
Hi all,
Firstly a big thankyou to forum member coolmaster for providing me with a p3 service manual! I have been made aware of an open directory in the Rega web page intended for use by rega service centers. Unfortunately you need a password to access the downloads section (presumably where service manuals are kept) but the open directory has a huge wealth of service information available for the entire Rega product line. Enjoy! Of particular interest: Cleaning Hub/Bearing Clean and re-oil motor |
#10 |
Bookmarked, thanks!
I used Valvoline 80w-90 gear oil since those specific models were not available. We'll see how it goes over time, but so far it sounds the way it should.
| Recommended Repairer | welshkid | Solid State | 1 | 12th June 2008 08:39 PM |
| Most Recommended books | jdlech | Multi-Way | 10 | 6th April 2008 08:57 PM |
| Recommended diy Pre for T-amp | t. | Class D | 12 | 21st June 2005 09:56 AM |
| Recommended MP3 Playback | Mikett | Digital Source | 1 | 8th November 2004 12:45 AM |
| Page generated in 0.09531 seconds (79.84% PHP - 20.16% MySQL) with 10 queries |
