Old 23rd May 2007, 06:59 AM   #1
Jamh is offline Jamh  United States
Jamh's Avatar
Default diy phono stylus gauge
OMG, I was laughing so hard making this.
What you need:
+ Any piece of wood, mine is 5.5x4.5in 1/2in thick.
+ A piece of bendable metal, mine is 12inx1.4in.
+ An L bracket.
+ A straw, one of those bendable kind.
+ A kitchen utensil to measure milliliters.
+ A toothpick
+ some tape
The trick to it is that water weighs 1g per milliliter.
Drill a hole, put a screw and nut.
Cut the toothpick, bend it on the 2 ends, tape it to the straw (cut symmetrical where it bends) and balance it on the metal.
Now pour 2.2 ml of water in it (what I needed exactly for my cartridge), or whatever you want. Mark where it balances, score it with a sharp knife for the stylus to rest on it.
Old 23rd May 2007, 07:01 AM   #2
Jamh's Avatar
You can put more lines, one per cartridge, if you want. Here it is balanced.
Old 23rd May 2007, 07:02 AM   #3
Jamh's Avatar
The grooves where the stylus rests.
Old 23rd May 2007, 07:05 AM   #4
Jamh's Avatar
Oh, the width of the metal, it should read 1/4 in, not 1.4in.
Old 23rd May 2007, 08:44 PM   #5
Jamh's Avatar
One obvious and important point: make sure the metal is non-magnetic. Ie. copper, zinc, anything but iron!!!!
Old 23rd May 2007, 11:05 PM   #6
Actually it doesn't matter if it's magnetic, as compressing the stylus does not change the Earth's gravitational pull on the cartridge. However, since aluminum is so inexpensive, easily worked, and easily come by, you can use something non-magnetic if it makes you happy.
Grey
Old 24th May 2007, 12:37 AM   #7
Jamh's Avatar
You're right about measuring the force, but if it were magnetic as you brought the cartridge close, the metal would jump to the cartridge and crush the cantilever!!!
Old 24th May 2007, 12:44 AM   #8
You know, I once knew a young lady who used to complain about my hands in approximately the same terms.
Until I managed to persuade her that my hands knew better what they were doing than she did.
After which we got along just fine.
You just need a more robust cartridge.
Or perhaps you need to brush up on your skills of persuasion.
Grey
Old 24th May 2007, 07:57 AM   #9
Jamh I agree, NON-metallic. If the cart tries to attach itself to any part of the balance beam it just adds difficulty to a simple task.
I could ask if you adjusted the weight of the water per the elevation of your location. The weight of water (specific gravity) is measured at sea level. But that would be silly, like talking about hands or whatever.
Nicely done project.
Old 24th May 2007, 08:01 AM   #10
Did it Himself
richie00boy's Avatar
What is the purpose of this? Is it to test the downforce against what you have set?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Now many hours does a stylus last? johnmarkp Analogue Source 21 2nd October 2008 06:36 PM
Stylus run in time?? emperor Analogue Source 15 13th April 2007 07:43 PM
year old stylus Bama Slamma Analogue Source 1 20th March 2007 02:56 PM
the right stylus/cartridge solonbro Analogue Source 38 2nd April 2005 09:24 PM
WTB : New phono Cartridge/stylus Ilianh Swap Meet 3 22nd June 2003 03:58 AM
Page generated in 3.75895 seconds (-74.51% PHP - 174.51% MySQL) with 11 queries
