| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
On Hiatus
So Bottom line is:
You can use a Hair Drier and some "Spectrum-Anylyse" software to calibrate your elektret-microphones. Have I got this right or .... ... am I not in the truth, yet /halo - wants to be where everyone else seem to be: - some place better .... |
#12 |
No. Hair dryer is no good at all! Use high pressure air 100 psi or more. Maybe you could try letting down your car tyre.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#13 |
Fan noise is most definitely not white noise. Acoustical engineers and submarine sonar operators can analyse the spectrum of fan (or propellor) noise and determine the number of blades and rpm. They then quieten it. The acoustical engineers charge a consultancy fee and use baffles/lagging. The submariners blow it up. They do not charge a fee.
Bicycle tyres (not mountain bikes) operate at 100psi, so that might be a good source in lieu of a compressor. Many thanks for an excellent calibration suggestion. |
#14 |
true bicycle tires (tubulars) go up to 200 psi
http://www.athenscyclepath.com/wconntubulartires.htmland road bikes go from 100-140 (clinchers) -Eric |
#15 |
Excellent. Loved the link. Tubs are the cycle equivalent of vinyl. I'd love to ride on tubs but balk at the sewing.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#16 |
i just built up a tubular wheel set.... the thing about the glue is true. its horrible.
i've wanted to go to vinyl but a) cant afford a nice turn table say a 1200. b) wouldnt have any thing but mom and dads old music...... any suggestions? on other decent players? and cheap ways to get albums? (i think my last one was the alf records that burger king gave out) -eric |
#17 |
that's what I did when I built my IMP with MLS.... because I WANTed to be able to correlate my measurements to manufacturers published graphs to see how accurate my measurements is to theirs or vice versa, albeit with one hiccup MLS ( maximum length sequence) pulse signals are more accurate at the top end than sine which a lot of them still use so you see tweeter performance as it really is at the top end.... anyway that depends on measuring system and location, how well one can gate the response acquired te remove room reflections or other artefacts that can affect your results,
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#18 | |
| Calibrating an emission tester | kenpeter | Tubes / Valves | 5 | 30th June 2008 04:56 PM |
| Flex hose as port in vented cabinet ? | Jan Dupont | Subwoofers | 19 | 27th March 2007 03:53 PM |
| Calibrating new tip on Hakko 929-2 / 903 | ultrachrome | Parts | 1 | 4th January 2006 02:28 AM |
| self-calibrating OPAMP | jackinnj | Swap Meet | 0 | 27th February 2004 05:03 PM |
| Calibrating a mic | Raka | Analogue Source | 1 | 29th January 2003 06:28 PM |
| Page generated in 0.09640 seconds (80.90% PHP - 19.10% MySQL) with 11 queries |
