Old 24th April 2007, 07:32 PM   #1
edwilks is offline edwilks  United Kingdom
Default Aligning Rega Elys Cartridge
Hello folks.
I have a Rega Planar 2, RB250, Elys cartridge, all circa 1998.
Although the cartridge uses Rega's 3 point fixing arrangement, there is enough slack in the holes to make alignment with a protractor necessary. Since the cartridge sides aren't parallel, do I line up the inner side, ie the one nearest the spindle, the outer side, or try to line them both up as best I can?
Also, are more recent Rega's machined so accurately as to make this unnecessary, or could life never be that simple?
Thanks in advance.
Old 24th April 2007, 11:13 PM   #2
bulgin is offline bulgin  South Africa
Default Aligning...
Hello Ed
Yes, it is indeed a problem if cart manufacturers are sometimes a bit thoughtless in their design parameters to forget about thinking about the users...
I would say it would be OK if you try to align the Elys using both sides (inner and outer) as best as you can with a protractor. Also, maybe it helps if the lines or grid of your protractor are fine enough to doublecheck also on the cantilever.
Good Luck
bulgin
Old 25th April 2007, 07:46 PM   #3
Thanks bulgin.
This came to me aligned on the inner side, by the dealer, hence my indecision.
Having now aligned it as you suggest, using the excellent (free) protractor from vinylengine.com, even my untutored ear'oles can tell it's right.
My 30 year old vinyl never sounded so good. Aaah...
Cheers, mate.
Old 26th April 2007, 12:19 PM   #4
Default Aligning...
Nice to hear that, Ed.
Enjoy the vinyl. There's nothing like it.
Cheers
bulgin
Old 18th May 2007, 08:52 PM   #5
Panicos K's Avatar
edwilks,your elys should have a plastic washer on the front third bolt.Using this,fits in the arms 's hole,to give a tight and correct position of the third bolt.So,all you need to do is to move the elys around this bolt untill you are sure that it sits symmetrically on the 250's headshell.
Old 21st May 2007, 08:07 PM   #6
tubenut is offline tubenut  South Africa
tubenut's Avatar
A bit off topic but where possible one should "align" the cantilever rather then the body as Bulgin mentioned. It is ther Cantilever that needs to be in the right position, we assume the cantilever is paralel to the body sides. In a perfect world it would always be so.
Guillaume
Croak Audio Exploration
Old 21st May 2007, 08:30 PM   #7
Panicos K's Avatar
Very true tubenut,very true.I have seen 2-3 brand new mc cartridges from a famous european manufacturer,and the body showed to the east,while the cantilever to the west.
aligning drivers mrkramer Multi-Way 17 24th February 2009 03:59 PM
Rega Bias MM phono cartridge (original green one) Glowbug Swap Meet 0 8th April 2007 09:58 PM
question about cartridge for rega p2 bluvenom Analogue Source 6 15th October 2006 10:18 PM
Which cartridge suitable for Rega P3/25 TT? henkel Analogue Source 7 8th April 2006 03:20 PM
Cartridge for Michell Tecnodec with a Rega RB300 Algar_emi Analogue Source 7 6th August 2005 03:14 AM
Page generated in 0.09135 seconds (74.25% PHP - 25.75% MySQL) with 10 queries
