| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I own a Meridian 101 with a MM phono input and I´m using it with a benz Ace Mid output (0.8mv).
I recently purchased a MC module but I did not try it because I am afrais it can be too sensitive fot this cart. Please advise about this possible change. Regards
#2 |
hi there,
i used to own one of these units and i had a couple of different input modules. there was as i recall 2 different MC modules from the factory. as i recall the spec is printed on the top. they could be taloired to suit different cartridges, input impeadance/ capacitance loading and gain. do you have the spec of the cartridge? might be worthwile giving meridian a call or email to check this out. however i would try it and see, making sure the volume is turned very low to start with. if the gain is about right there will be a 'nice' spread of ajustment with volume control. regards bob
regards bob |
| Moving Coil preamp design | paul joyce | Solid State | 162 | 26th October 2010 11:36 PM |
| Moving Coil cartridge experiment | bulgin | Analogue Source | 13 | 9th January 2007 08:57 PM |
| Moving coil meter: where to buy? | Thoru | Parts | 4 | 3rd January 2006 04:28 PM |
| moving coil loading | lt cdr data | Analogue Source | 28 | 27th June 2005 10:50 PM |
| SL10 Moving Coil Stage | johnsciolino | Pass Labs | 1 | 25th October 2004 06:05 PM |
| Page generated in 0.06949 seconds (79.89% PHP - 20.11% MySQL) with 10 queries |
