How to use DC supply with phono preamp? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd March 2007, 11:04 AM   #11
Did it Himself
richie00boy's Avatar
Curious why you think that op-amp change will do anything for DC offset - both are FET input chips.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 23rd March 2007, 12:31 PM   #12
Sigurd Ruschkowski has demonstrated that the AD8620 will eliminate DC offset, which is a problem for the Bugle.
http://www.audiocircle.com/circles/i...?topic=21339.0
Old 23rd March 2007, 04:51 PM   #13
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
my question also ?
Originally posted by audioPT
BTW2... Why not Bugle's Power Supply?
Old 23rd March 2007, 11:49 PM   #14
Originally posted by mlloyd1
my question also ?
I already responded to that:
Originally posted by JWFokker
You know, that's probably the best idea. I had forgotten about it when trying to figure out how to get my power supply to work with the Bugle. I wonder though if I can just use a 12V transformer in the Bugle power supply, rather than the 15V it calls for, because I installed an AD8620 opamp in place of one of the OPA2134PA's to eliminate DC offset, and the AD8620 is only rated up to 13V.
Thanks for all your help.
Old 25th July 2008, 03:21 AM   #15
So I'm revisiting this after forgetting about the Bugle for a long while...
And it looks to me like I could just use two traditional DC power supplies or use a 24VDC supply (which I happen to have) and use a supply splitter? The TLE2426 is cheap, but is there a simple kit or PCB board that will allow me to use it for this? According to the Bugle manual, two 9V alkaline batteries (580mAH) should last 16 hours, so that works out to about 36mA draw from each battery if I did the math correctly.
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Power supply for 12SL7 phono preamp HawkSpeed Tubes / Valves 28 25th June 2008 03:00 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
In search of power supply schematic for phono preamp jduffy Tubes / Valves 16 9th April 2007 04:58 PM
Having trouble building a power supply for a phono preamp SideA Solid State 1 4th April 2003 06:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
