Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th March 2007, 05:47 AM   #1
Default hookup wire question
Hello,
I have a few questions on hookup wire. I am getting ready to rewire my Transcendent Sound Tube Pre-amp. I originally bought DH Labs 18 gauge 99.99% silver wire. However, I have found out that it is too large of a gauge wire and this larger diameter wire might cause some audible transient smearing or confusion, depending on the bandwidth of the tube pre. Here are the specs:
Harmonic Distortion: Less than .02% at 2 volts RMS out.
Signal to Noise Ratio: Greater than 93 dB.
Bandwidth: 1 dB down from 5 Hz to 300 kHz.
Gain: 12 dB.
Max Signal Out: 20 volts RMS.
Output Impedance: 200 ohms.
Input Impedance: 50 k Ohms.
Inputs: 3, Outputs: 1, all single-ended, RCA
Controls: Input Selector, Volume, Power
Tube Compliment: 3-12AU7
Dimensions Overall: 15'W by 11'D by 4 1/4'H.
Weight: 10 pounds.
Is there a sonic difference between solid and standed wire? Or is solid wire just easier to work with?
So, my question to you guys is should I buy the 23 gauge DH Labs pure silver wire, go with a solid 20 gauge teflon coated silver plated wire, use the inner core of Belden 1506a wire (which I have) or use some other 20 gauge solid copper wire? My setup right now is right in between forward sounding and laid back.
Thanks,
Dan
Old 6th March 2007, 07:17 PM   #2
Panicos K's Avatar
I would go for the 23awg silver if these are your only choices
Old 6th March 2007, 07:18 PM   #3
Panicos K's Avatar
mostly due to it's small diameter
Old 6th March 2007, 08:29 PM   #4
gary f is offline gary f  Canada
gary f's Avatar
Well, if you ask me, I would not be worried about "transient smearing" with 18 gauge wire. And don't worry about the frequency response above 50K (or maybe 100K if you are really serious about bandwidth), don't forget that you can't hear it and/or that your speakers cannot reproduce it and/or that your source does not provide it, so don't worry about that.
My opinion about wire is that solid core is easier to work with and hold on better. It looks neat. The sound? Well I don't know really, but I'm pretty sure it's fine.
F
Old 6th March 2007, 08:46 PM   #5
Panicos K's Avatar
i think is better to use thinner than thicker wire in line level signals.18 awg could be used as a speaker cable by many.
Old 6th March 2007, 10:18 PM   #6
Thanks for the replies. Panicos, if you could use any hookup wire, what would you use then to wire up a tube preamp? I am not locked into buying anything at this point.
Dan
Old 6th March 2007, 10:43 PM   #7
Panicos K's Avatar
At the phono input if any,I would(and I am using in my Quad pre)around 26-28awg which I find to give better low level information than thicker types.At the line inputs and output you could use a slightly thicker wire,say 22-24awg,and if you will rewire internal mains wires,try one at around 20-18awg.Don't ask me why,but playing with these for a long time,to my mind and ears sounds fine.But if you want to have some fun,do some experiments.I'm sure you'll enjoy it.
Old 6th March 2007, 10:47 PM   #8
Panicos K's Avatar
One more thing Dan,a solid core wire will give a slightly dryer ''sound''than a stranded one.Personaly,I prefer the slightly richer stranded types.
Hookup wire Buzzy Solid State 6 4th July 2008 02:39 AM
Aluminum Hookup Wire jsa_ind Everything Else 14 13th January 2007 10:05 AM
Hookup Wire Q matthewm Chip Amps 3 22nd November 2006 05:06 PM
Hookup wire gauge question Prune Everything Else 2 5th February 2004 08:11 PM
Page generated in 0.12281 seconds (68.42% PHP - 31.58% MySQL) with 10 queries
