Line Level Question? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd March 2007, 06:34 PM   #11
ROBSCIX is offline ROBSCIX  Canada
SO this is your professional opinion? -What I mean is I don't want to relay this info to other people and they blow the inputs on their amps/Receviers. I actually thought it wouldn't do anything.
So one should be able to put the card to 100% and not worry about hurting the gear right? -most won;t becasue you may get distortion from the card...maybe
thx for your advice BTW...
Old 22nd March 2007, 06:55 PM   #12
Did it Himself
richie00boy's Avatar
It's a professional opinion The only damage could be if they allow full on the dial, they will smoke their tweeters and possibly woofers too.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 22nd March 2007, 07:13 PM   #13
Frank Berry's Avatar
Default Re: Line Level Question?
Originally posted by ROBSCIX
If a audio device has a maximun output of 5V and it's meant to be connected to a line level input would damage be casued by this high amount?
I asked a few people but seem to get unclear answers I know "normal" line leve is around 2V BUT does supplying more damage the inputs or just drive them harder? Another pseron just said the amp will just amplify what is at the input..I don't know this is why I am asking. Thx for nay help you can give me guys.
I would imagine the 5v would be a peak voltage....
Maximum output voltage has very little to do with the output voltage that the device will deliver under normal operating conditions.
I have designed preamps that can deliver 50 volts RMS before they clip. Under normal operating conditions, these preamps will deliver a couple of volts. The difference between the normal operating level and maximum output level is called HEADROOM.
Frank
Old 22nd March 2007, 07:56 PM   #14
I understand about headroom BUT I was thinking that with 5Vrms would drive the signal through the roof and cause clipping. What would be the ~normal amount of signal a recevier could handle?
So basically I should be able to driver this card with %100 signal and I won't cause disortion and won't hurt the unit at all?-the recevier or amp?
-do you have a ~voltage level a receiver sould handle on it's inputs befoer damage would occur?
-I really appreciate your help on this I have been looking around for info for along time and got varying answers.
Old 22nd March 2007, 08:51 PM   #15
Did it Himself
MORE THAN 5V.
Please, it's all going to be fine. You can sleep at night
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
Line Level question? ROBSCIX Chip Amps 13 4th February 2007 09:31 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
Speaker to line level adapter circuit question. Flatlander Parts 5 10th May 2006 12:33 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
Copyright 1999-2017 diyAudio
