Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd January 2007, 10:28 AM   #1
h_a is offline h_a  Europe
h_a's Avatar
Default using a transformer for balanced to unbalanced conversion
Hi all!
I'm thinking of using balanced connections from my cartridge (a MM) to the phonostage and converting the signal there to unbalanced (since that is what is used internally).
Is it correct that I gain with balanced wiring +6dB voltage from the cartridge?
That would mean double voltage?!
But how's that possible?
That would mean that the - signal is also used (instead of being connected to ground), ok then I should have +6dB. On the other hand the secondary of the transformer is again grounded and I do get the full voltage - so this should be true also for the cartridge which would mean that there is no double voltage then.
Please help me out of this!
Thanks a lot!!
With kind regards, Hannes
Old 3rd January 2007, 05:55 PM   #2
Steve Eddy's Avatar
There would be no voltage gain, assuming you're using a 1:1 transformer.
The reason people have this notion of balanced somehow inherently meaning a 6dB voltage gain is because often what's done to create a balanced output is to send a single-ended signal to two amplifiers, one non-inverting and one inverting. That will give you 6dB of voltage gain over the single-ended output.
When using a 1:1 transformer to do balanced to unbalanced or unbalanced to balanced conversion, the voltage out is equal to the voltage in. Ideally anyway. There will be some amount of insertion loss with any realworld 1:1 transformer, but that's beside the point.
se
Old 3rd January 2007, 06:42 PM   #3
phn is offline phn  Sweden
phn's Avatar
I'm as big a transformer fan as they get. But I would never use transformers is this case. Whatever pros there may be, I can't see them outweight the cons.
Old 3rd January 2007, 09:31 PM   #4
Steve Eddy's Avatar
Oh yeah? I bet I'm a bigger transformer fan than you are! So there!
Yeah. The cartridge's output is already balanced so there's no need to use a transformer to balance it, especially if it's just going to feed an unbalanced input at the phono stage.
An input transformer at the phono stage would be helpful for providing a good deal of common-mode noise rejection, but it would make cartridge loading a bit problematic.
se
Old 4th January 2007, 07:33 AM   #5
h_a's Avatar
Guys you got me wrong.
I want to use the balanced output from the cartridge to the phonoamp and convert it then to unbalanced!
That's the point the trafo comes in.
However I do understand now that there's no voltage gain, in contrast to what I was repeatedly told by some manufacturer. Indeed Steve Eddy - thanks!! - explained what the manufacturer seems not to be able to!!
What about cartridge loading?
I just need to add the capacitors (MM needs them) on the primary side, from + to ground and also from - to ground, right?
Since this would be a 1:1 trafo, the 47k on the secondary side will also appear on the primary - right?
Thanks for all your help!!
Old 4th January 2007, 11:07 AM   #6
pooge is offline pooge  United States
The phono cartridge is not necessarily balanced. While it may start off that way, one side of the coil may be connected to ground in the headshell.
Old 4th January 2007, 11:24 AM   #7
phn's Avatar
Lets say you add 50k:50k input transformers on the phono stage and add XLRs.
Still there would be little to gain.
And if you go this distance you can just as well get a step-up transformer insted of the 50k:50k one and a MC cart.
Old 4th January 2007, 12:13 PM   #8
h_a's Avatar
@phn: MC is not generally better, although highend-people believe so.
What do you mean with 50k:50k? Trafo-impedance? I usually see values like 600Ohm for MCs or mics and 10k for line input?
@pooge: yes you're perfectly right! In most cartridges at least 1 channel is balanced, the other - regardless wether it's MM, MC or something else - is usually connected to the cartridge's case.
However even then the balanced solution should work, since the trafo sees double height + & GND instead of + & -??
Or I can isolate the cartridge from the tonearm, so there would be no connection to ground then. Of course the case is then electrically active and no longer grounded...do you think this would cause problems?
Thanks for your replies!! With kind regards, Hannes
Old 4th January 2007, 12:49 PM   #9
some cartridges have a removable shorting link from one pin to the case/arm.
regards Andrew T.
Old 4th January 2007, 01:19 PM   #10
h_a's Avatar
Which ones? Could you name some brands?
I want to use a Shure and a Nagaoka cartridge. At least the Shure has a visible link from one pin to its case but it doesn't look removable. The Nagaoka hints about internal grounding in its operating manual.
Do you think I would run into problems isolating the cartridge from the arm? It would become electronically active and would be no longer grounded.
What do you think?
Cheers, Hannes
Unbalanced to balanced input conversion? SQLGuy Solid State 53 19th October 2009 01:39 AM
unbalanced to balanced conversion neazoi Chip Amps 4 5th August 2008 12:45 PM
Line input transformer for unbalanced to balanced conversion okapi Chip Amps 23 12th January 2008 05:29 PM
Balanced to Unbalanced w/ Transformer? lgreen Solid State 9 6th January 2004 04:37 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
Page generated in 0.13502 seconds (72.00% PHP - 28.00% MySQL) with 10 queries
