Question about soldering the balanced interconnect cable
Old 6th September 2006, 02:02 PM   #1
rnzr is offline rnzr  Estonia
Default Question about soldering the balanced interconnect cable
Hi
I want to recable my Pro-Ject Debute turntable with the DH-Labs BL-1 balanced interconnect cable (with rca's).
I've done many "telescoping shield" (shield is grounded on the signal side of the rca's) rca interconnects but don't have experiences with the turntable wiring, does it work good on turntables too...(?)
So should I terminate the shield on the turntable side to the ground like "telescoping shield" type cable? (The cable must soldered directly in turntable, it doesnt have rca jacks) Or should I left the shield untouched?
Suggestions are welcome...
Old 6th September 2006, 02:22 PM   #2
Gooch is offline Gooch  United States
Gooch's Avatar
Hi rnzr
This is what I would do take one wire solder it to the center pin of the RCA the other wire to the shield of the RCA now the Shield of the balance cable would also be attached to the shield of the RCA but not at the turntable hope this make sense
Dave
Old 6th September 2006, 02:46 PM   #3
so i should solder the shield wire to the rca ground? and leave the shield open at the turntable side?
Old 6th September 2006, 03:02 PM   #4
Gooch's Avatar
Yes that's right
Dave
Old 6th September 2006, 03:06 PM   #5
ok, thanks but can you tell me Dave why is that better than the opposite option? better noise cancelling?
Old 6th September 2006, 03:23 PM   #6
Gooch's Avatar
Well don't quote on this I guess noise coming from the TT would be cancel out if the shield was connected at the TT. But if you have to solder right to the TT then it might be harder to do then the other way I don't know what your TT looks like. Try it either way and see if you hear any difference it can't hurt.
Dave
Old 19th September 2006, 08:48 AM   #7
thank you for your reply's!
rewiring done and results are very good
click on a pic to see gallery...
Old 19th September 2006, 02:24 PM   #8
Gooch's Avatar
RNZR
Nice work they look really good glad you like it.
Dave
Question about soldering the balanced interconnect cableHide this!Advertise here!
If you were looking for the best interconnect cable ... lowtherdream Parts 3 13th August 2008 03:07 PM
Balanced interconnect to differential amp - how would you do it? zigzagflux Tubes / Valves 11 5th February 2008 03:36 AM
Interconnect cable Midnite Mick Parts 3 3rd January 2007 07:47 PM
interconnect cable 15' long Jaime Tubes / Valves 3 10th December 2006 01:32 AM
Wires for balanced interconnect hbarki Parts 4 28th April 2005 03:10 AM
Copyright ©1999-2017 diyAudio
