Lightspeed Attenuator a new passive preamp
Old 10th October 2017, 02:03 PM   #5681
udailey is offline udailey  United States
Doesn't matter. If ldrs are well matched you will keep channel balance. What changes is the volume curve which might or might not be perfect even if both were exactly 100k.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 10th October 2017, 03:54 PM   #5682
No
Old 10th October 2017, 07:42 PM   #5683
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Channel accuracy of the Dual 100kohm log pot is not important, what is important is that you use a 100kohm log dual pot and it is wired as per the circuit diagram.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 10th October 2017, 07:43 PM   #5684
ozapaydin is offline ozapaydin
Thank you, guys.
Old 13th June 2018, 12:07 AM   #5685
haiqu is offline haiqu  Australia
haiqu's Avatar
Just received my 32SR2(Sorted) delivery yesterday and did a quick match within +/- 0.5 ohm at 2mA. Unfortunately my el-cheapo diode tester doesn't go any lower than that. Of the 25 received I got three quads, two triples, three pairs and one oddball. They were all of the same batch (A) and all were close to 40 ohms at 2mA so should be well below that at 20mA.
GeorgeHiFi, thank you for this. I started to design a passive preamp years ago and gave up due to the rubbish parts available. I can finally dig that chassis out and fill it with goodies. I'll probably use a 78L05 since it will handle 100mA easily and I don't plan to add anything else to it.
One thought: it may be possible to cancel much of the temperature drift by using a thermistor instead of the 100 ohm resistors. I didn't read the whole thread - hey life's too short! - but in scanning every 10th post or so I didn't see anyone mention that possibility. Then again the value is too small, isn't it.
[VK9VK] With great power comes great current squared times resistance.
I spent most of my money on fast cars, hot girls, hi-fi gear and booze. The rest I just wasted.
Lightspeed Attenuator a new passive preampHide this!Advertise here!
