Lightspeed Attenuator a new passive preamp
Old 12th August 2012, 12:34 PM   #4791
I recommend double filtering of the RF that flies around the modern home.
1. At the input to the power amp.
2. at the input to the box/screen that contains the power amp.
For 1. I use a 0.68us time constant, but any value from 0.3us to 1.5us are commonly used.
For 2. I use a 47pF directly across hot and return on the RCA input socket.
You may find that one or the other is adequate. But with all the radio transmitters around the modern home and in your neighbours', then I believe that more RF attenuation is better than audio contamination.
regards Andrew T.
Old 12th August 2012, 12:48 PM   #4792
portreathbeach is offline portreathbeach  United Kingdom
Thanks. I'll have to experiment
Old 13th August 2012, 01:21 AM   #4793
Pass lover is offline Pass lover  United Kingdom
Hi
I am not upto date with the threats
Does anyone know if George did make 7.1 pre amp for home theater use? Can I order from him?
The set up is for connecting Oppo 95 7.1 analogue output to the power amp.
Old 13th August 2012, 01:38 AM   #4794
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Originally Posted by Pass lover View Post
Hi
No sorry, only two channel for stereo use, a 7.1 would be a nightmare to do and get right, if at all. better off using one of these CT2 8 channel ones.
DACT audio attenuators
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 14th August 2012, 03:50 AM   #4795
thisisvv is offline thisisvv  United States
may be this is asked many times, how hard is to make this for a guy who hasnt soldered in a decade...
also any place where i can get this
Old 16th August 2012, 09:50 AM   #4796
studiostevus is offline studiostevus  Netherlands
Originally Posted by georgehifi View Post
If the stage after the Lightspeed is 100k input impedance then the input impedance of the Lightspeed is between 10k-15k,
Here is the Graph that Tom Gootee plotted for the input impedance of the Lightspeed Attenuator (how I make them) for three different poweramp input impedances.
Thanks again for the graphs Tom!
http://www.diyaudio.com/forums/analo...ml#post3015694
Cheers George
I have been trying to get my head around this but can't figure it out....
I am looking to replace the output capacitor of my dac with a better one, and I am trying to pick a value for this cap (as low as possible is best, as I want to use something good/expensive).
My setup:
Dac(tube output) --> Lightspeed --> Aikido LV preamp --> Pass F5
Can someone help me to select the right size output cap for the dac?
I don't want to use another buffer stage tbh.
Old 16th August 2012, 10:42 AM   #4797
georgehifi's Avatar
4.7uf will be plenty with the combined resistance of the Lightspeed and input impedace of the Aikido.
Cheers George
Old 16th August 2012, 11:26 AM   #4798
wow... that seems awfully high...
Am I wrong to assume that the impedance of the combined Aikido+Lightspeed should be well above 100K ?
Old 16th August 2012, 11:37 AM   #4799
georgehifi's Avatar
It will be around 10k.
Cheers George
Old 16th August 2012, 11:49 AM   #4800
Didn't expect that....!
I would be suprised if the others who have build and are using the lightspeed are aware of this and have adapted their source equipment to suit this!
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2017 diyAudio
