Lightspeed Attenuator a new passive preamp
Old 12th January 2012, 02:29 PM   #4391
udailey is offline udailey  United States
Passive Aggressive
Originally Posted by BFNY View Post
My understanding is you recommend a constant fixed value for the LDR then, set by a trimpot? From your experience, can this be set to say, in the range of 20k to 40k ohms?
Again, comments appreciated as to why this approach would be preferred over, say, a fixed high quality tantalum or other boutique resistor of the same value.
You could use a single LDR or two set up as a voltage divider. You can set them at those high values but they dont stay stable at those high values. Even at 10k you can see a single LDR fluctuate by 400R or so when you blow on it. The higher in value the less stable. So a voltage divider will do the trick at lower values. Its not the best ever solution, but it will work and will sound better and likely cost less than boutique resistors or at least cost about the same.
OOOH, you could also throw a switch in there that enables the shunt LDRs in your static resistance circuit to go to 40R so when you want very low volume just throw that switch. Its admittedly a kludge but hey it WILL work and its not even special magic.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 12th January 2012, 03:11 PM   #4392
Passive Aggressive
I think its time for me to release boards so guys can do their own matching. This way we can avoid all this crazy conjecture and everyone will see for themselves.
Plus I am pretty tired of matching. It truly gets boring. I prefer working on circuits and finding something new.
Anybody thats interested shoot me an email. Will throw in free Lightspeed boards.
Old 12th January 2012, 08:30 PM   #4393
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
The specs on the data sheets don't lie
http://www.diyaudio.com/forums/analo...ml#post2850064
and this was backed up to me by Fred P. Rohrbacher V.P. & General Manager of Silonex a Casco Company and I have done thousands of these now and I can verify it's fact, that the NSL32SR2S goes far lower in impedance at the same given led mA current than the NSL32SR2 can without stressing by over driving the led with more than 20mA.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 3rd February 2012, 09:06 PM   #4394
georgehifi's Avatar
All you proud Lightspeed Attenuator owners and builders, look out for the upcoming Stereophile issue (I think April issue which comes out in March) with Recommended Components listing, as they just emailed me for any changes (pricing, design etc) to be included in the write up on it.
This will be the 5th time your Lightspeed Attenuator has made it into Recommended Components since 2009 when Sam Telling first bought his from me. I have a feeling it may set some sort of record for Recommended Component longevity.
Cheers George
Old 14th February 2012, 07:37 PM   #4395
djn is offline djn  United States
djn's Avatar
Hi All, I am building a passive pre and heard the lightspeed and was VERY impressed. I am a good and creative builder, but a little lame on the workings of electronics....please forgive. I have heard that the lightspeed needs a certain range of impedance both coming and going. SO, it will be going into a Pete Millete Low Mu preamp then on to 3 amps. For inputs, I have a CD player that goes into a tube DAC, an octal phono pre, music server that goes into the same DAC as my CD, and FM tuner (at some point in time) The tube DAC is the Maverick D1.
So, will the lightspeed work with these inputs and the tube preamp?
Old 14th February 2012, 08:11 PM   #4396
georgehifi's Avatar
Hi djn, the Lightspeed Attenuator in it's purest form, with no buffers or extra series or shunt components, as I have attached, using quad matched NSL32SR2S led/ldr packages.
1: like to have sources (cdp,tuners,dacs, phono stages etc) of less than 200ohms output impedance (which most are theses days)
2: The input impedance of the poweramp should be higher than 47k (which most are) as 47kohms is the industry standard, tube amps are generally higher which is great. Many customers of mine have still had great results down to 33k poweramp inputs.
3: interconnects from the Lightspeed Attenuator to the poweramp should be 1.5mts or shorter and of low capacitance 100pf per foot or less which most good quality one's are.
And you can use one of these led testers (attached) and your DMM on the ldr to do the quad matching, $5 at your local Rat Shack or similar.
Cheers George
Old 14th February 2012, 11:12 PM   #4397
mike_mcf is offline mike_mcf  Canada
Cheers George
With all due respect, the Linn Sondek was in the recommended products for 20 to 30 years and may still be there today.
Michael
Old 15th February 2012, 01:34 PM   #4398
djn's Avatar
Thanks George. I think this will work out well. I'd like to have a semi professional look about it. Does anyone sell boards and bits? Also, since I am getting or have gotten old, I want remote controlls on the V-pot. The only ones I can find have circuits of some sort attached to them. Is there anywhere I can get just a V-pot with a remote motor and controll board attached?
Old 15th February 2012, 01:51 PM   #4399
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
check ebay...here's one.
MV02 4way input Motorized Remote Volume Control Kit | eBay
Old 15th February 2012, 03:16 PM   #4400
If all you are looking for is a motorized pot, then there are lots of them available online. Google search.
Michael
Lightspeed Attenuator a new passive preampHide this!Advertise here!
