Lightspeed Attenuator a new passive preamp
Old 21st November 2011, 08:11 PM   #4311
udailey is offline udailey  United States
Passive Aggressive
Yes for sure you can do this a wonderful job with 2 Volume pots. It can be perfect matched voltage output from the two channels. Their total resistance might be a bit different but you will have what you wanted. Most folks complain about adjusting even one pot LOL so two pots doesnt come up often.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 21st November 2011, 08:12 PM   #4312
Passive Aggressive
Thats super cool software. What is it?
Old 21st November 2011, 08:35 PM   #4313
redmaster is offline redmaster  Poland
that's RME digicheck,
you have to got RME interface I think....
it's amazing tool
Old 21st November 2011, 08:51 PM   #4314
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Originally Posted by redmaster View Post
here is a video file,
LDR l+r imbalance - YouTube
please note how it starts from imbalance, get even in the 'middle' around -20dBFS, and then starts getting imbalance again, but now another channel is louder
I am happy to have 0.2dB, but if it's 1dB difference - then in my situation it's not good
do you think 2 separate ldr volume pots and precise VU meter could be an option ?
Even matched tweeters from B&W for their 801's monitors are within +- 1db that's 2db spread overhaul, as stated to me by B&W when I owned a pair that needed them replaced when one blew.
If you have a detectable shift difference in image while music is playing at different levels, then it's bigger than .5db, also what you have shown to me indicates not a good quad matched set at 5 different mA points, from 1 to 20mA
Yes if you want to fix this problem without having to rematch your set, (you may have unmatched them with too much heat while soldering) you can use dual left and right 100k single pots, as I do offer this as an option in the production Lightspeed Attenuator for those who have system/speaker or room imbalance problems.
But I also state in the Lightspeed advertising pdf that it is more user unfriendly as they (the two separate pots) take time to get balanced when different cd levels are used and volume is changed.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 21st November 2011, 10:03 PM   #4315
I am really passionate about 'transparency' of ldr's audio,
I read on another forum ppl talked about passive attenuators, someone mentioned atty a design, the 1in 1 out passive attenuator as being completely transparent. Transparent means - you record output of device and then swap phase 180 and sum it with original file - if it nulls - means 100% transparent - you can always say you can hear difference, but null test doesn't lie
I am interested about yours opinion
Old 21st November 2011, 10:15 PM   #4316
Passive Aggressive
You should compare the two. I can do the same test with metal film resistors and then replace with an LDR and get better sound. Still measures the same. This doesnt bother me because my ears are hearing something the equipment isnt showing me.
Old 21st November 2011, 10:17 PM   #4317
Passive Aggressive
Oh, by the way I did this recently and am publishing a little project about it on diyaudioprojects.com
I want them to get to release the tiny circuit but then I will link here so you guys can check it out. Its not the biggest deal in the world but I replaced a resistor in my amp with a LDR and the difference was not small. Replaced a PRP.
Old 21st November 2011, 10:20 PM   #4318
null testing is not about measuring,
you swap phase 180 degrees and add to original file, when it nulls - means it's identical, and your ears/brain 'hear' something which does not exist,
null test is very efficient way to judge audio
Old 21st November 2011, 10:31 PM   #4319
georgehifi's Avatar
When I've talked about the transparency of the Lightspeed Attenuator having the least sonic signature (true to the source) of any preamp.
It's compared to direct connection into a poweramp from the source. Any other preamp passive or active has a far greater sonic signature than the Lightspeed with this way of comparing.
All volume pots switched or resistive track sound different as they all have a lightweight wiper contact (diode effect) of varying degrees, this is why if you clean and tighten your rca plugs your sound changes usually for the better, the wiper in a volume pot is even worse for this as it is a very small area of very light pressure when compared to an rca plug, and the diode effect is trying to rectify the ac music signal especially during heavy transients.
The Lightspeed is so close to a direct connection, it is almost undetectable when A/Bing. I still believe that direct connection is the perfect way of staying true to the source, but you do need a digital volume control in the cdp/dac done in the digital domain before the dac chip and to be able to use it in the top 20% of the full output range, otherwise you do run the risk of bit stripping if below 20% of full output.
Cheers George
Old 21st November 2011, 10:43 PM   #4320
Passive Aggressive
I understand what you are saying now. I wonder if we did something like this with a .1% SS amp and a .1% tube amp if we would hear the warmth of tubes left over.
Uriah
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2017 diyAudio
