Lightspeed Attenuator a new passive preamp
Old 17th September 2011, 02:24 AM   #4241
soongsc is offline soongsc  Taiwan
soongsc's Avatar
The LDRs themselves seem to have a log characteristic.
Hear the real thing!
Old 17th September 2011, 09:06 AM   #4242
portreathbeach is offline portreathbeach  United Kingdom
Thanks George, your schematic in post #4240 is the one in which I have created in Eagle.
Obviously this design only really needs 2 matched pairs, but as you said, quad matched will obviously be better. As for the 5 volt supply, can this be on the same PCB as the LDRs? or is it best to keep it separate for noise?
You also show in your drawing that the feed to the 7805 is 9 - 18v, these have a max input of 35v according to the datasheet, so would my 25 v be OK, if the regulator was bolted to my heat sink along with the amp chip?
Your MKII circuit shows only 1 100K log pot, this should work with the MKI schematic also shouldn't it? 5v to the wiper, one end to one pair of devices and the other to the other pair.
Old 17th September 2011, 12:20 PM   #4243
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Obviously this design only really needs 2 matched pairs, but as you said, quad matched will obviously be better. As for the 5 volt supply, can this be on the same PCB as the LDRs? or is it best to keep it separate for noise?Supply for the led's is totaly isolated from the ldr's so yes it can be on the same board
You also show in your drawing that the feed to the 7805 is 9 - 18v, these have a max input of 35v according to the datasheet, so would my 25 v be OK, if the regulator was bolted to my heat sink along with the amp chip?Yes the more you sink the hotter it will get
Same as for both, one trimmer only on the louder channel
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 17th September 2011, 04:33 PM   #4244
Thanks George. In your schematics, you have signal GND and the 5v power GND together, would it not be better to keep them separate, like this:
Also, just looking at the LM7805 regulators, because the current this circuit uses is so small (not much more than 50mA) and the regulators are rated at 1A or some at 1.5A output, it shouldn't get very hot, especially if it connected to the heat sink.
Old 17th September 2011, 05:57 PM   #4245
Another quick question. What is the need for a series and a shunt LDR?
Could you not substitute the series LDRs for (1K resistors for example) and then alter the resistance of the shunt LDRs, therefore only needing 2 devices?
I understand in a normal input pot setup, it is 'seen' by the previous piece of audio equipment as the total of resistance of the pot and this is always the same. But surely using 2 x LDRs, you are not guaranteeing a constant input impedance, are you?
Again, sorry if these questions have been answered previously, I have only just got to post #951
Old 17th September 2011, 06:47 PM   #4246
Marra is offline Marra  United Kingdom
I believe that was Georges mk1 version. The mk2 and better sounding ? version uses the four ldr's. This thing does sound good; just gets out of the way of the music.
Old 17th September 2011, 07:27 PM   #4247
Hi Marra. The drawing I have done is a copy of the MKI version (post #33), the MKII version uses a single pot and one trimmer I believe.
Are there any reasons why having a varying impedance (using a fixed resistor and an LDR) other than a more steady input impedance (series/shunt setup) would benefit. Does audio equipment NEED to 'see' a fixed impedance? If it doesn't, then wouldn't a single LDR and resistor on each channel be easier to implement and give a smoother curve, as you are only adjusting one resistance, not 2.
Old 17th September 2011, 08:59 PM   #4248
georgehifi's Avatar
Sorry the powersupply is not grounded to the chassis or signal. It makes no discernable difference if it is, I just let it float because it can, as wall warts have no earth and the led and it's powersupply have no electrical connection to chassis or rca earth.
Cheers George
Old 17th September 2011, 09:05 PM   #4249
Hi George, thanks for your input. What would happen with a circuit like this:
Not sure if 200K would be high enough.
Any thoughts on how this would work
Old 17th September 2011, 09:05 PM   #4250
georgehifi's Avatar
There are many advantages mentioned for the MKII over the MKI, but the MKII is much harder and costlier to make, otherwise I would have stuck with the MKI.
Cheers George
Cheers George
Lightspeed Attenuator a new passive preampHide this!Advertise here!
