Lightspeed Attenuator a new passive preamp
Old 7th December 2010, 04:49 PM   #3821
On Hiatus
SY's Avatar
That assumes input stage Johnson noise is dominant. In many designs (e.g., Joachim's or syn08's), one can reduce input stage noise to below the intrinsic Johnson noise of the source, so the 3dB penalty is moot. In other designs (like mine), those analyses are not valid.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th December 2010, 06:12 PM   #3822
ondesx is offline ondesx  France
May be an important precision must be recalled here... We are speaking of two different things. The balanced nature of the cartridges AND the use of the current mode instead of the voltage ! Even there are some "current preamp" on the market (for example 47Labs, the various Dynavectors, the ESE Nibiru, Jean Hiraga's DIY) the balanced version of this current preamp is rare !...
Then, most of the drawbacks of the balanced voltage preamp don't apply to the current mode preamp. The amplification in current mode, for example, does not require any impedance matching.
Old 7th December 2010, 08:22 PM   #3823
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
Originally Posted by georgehifi View Post
And then there is dacs/cdp's with so called balanced outputs, very few are balance all the way from the dac chips outputs right through to the xlr connectors usually they are single ended from the dac chips through the I/V stage then through 2 opamps to give the balanced output where the same but single ended output goes through 1 opamp after the I/V stage
Cheers George
This would not be the case.
Nearly all high performance DAC chips these days are balanced OP. They do
this specifically to get very low distortion figures through cancellation of
(some of) the even order components.
WRT all of those opamps, one of the best upgrades you can do to most fully
balanced voltage OP DAC's is throw away the whole back end and use a
VHQ line OP transformer such as Jensen or Cinemag.
Then you get a true galvanically isolated, bal or unbal OP - just like in
studios in the old days when they made great sounding recordings
Terry
Old 8th December 2010, 12:09 PM   #3824
nicoch58 is offline nicoch58  Europe
No good idea put a DMM on the cartridge!!
Old 11th December 2010, 03:35 PM   #3825
kerux is offline kerux  United States
Thumbs up I finally got my lightspeed working
I finally got my lightspeed working and it sounds amazing. I used Quanghao's pcb of Salas's Low Voltage Shunt Regulator circuit to power it.
My wife is also amazed at how good my stereo sounds now.
Thank you George, Salas and Quanqhao for providing these circuits and pcb.
Old 11th December 2010, 05:34 PM   #3826
AndrewGM is offline AndrewGM  United Kingdom
Oh great - a Lightspeed post at last !!
It's been all about cartridges, balanced stuff and pro audio recently.
Nice one Kerux - congratulations.
I'm recently a convert too and I'm still delighted with mine.
It's a big upgrade.
Your power supply sounds interesting - I'll check that out
Andrew
Old 12th December 2010, 05:41 PM   #3827
Marra is offline Marra  United Kingdom
It's a big upgrade.
Andrew
Andrew;
Check out dvb-projekt's Salas shunt regulated boards for powering the Lightspeed
Old 12th December 2010, 11:18 PM   #3828
TheShaman is offline TheShaman  Europe
How hard would it be to make a balanced version of an LDR attenuator?
Old 12th December 2010, 11:26 PM   #3829
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Wish you luck on the matching, and have some Valium handy.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 13th December 2010, 07:52 AM   #3830
markusA is offline markusA  Sweden
markusA's Avatar
I bought my matched ldrs from a friendly person on this board. costs are a premium but it saved me many grey hairs.
I actually have the case now and most of the small bits and pieces. As soon as I manage to free up some time I'll start assembly.
(Three projects running in parallell and my classes at the local techical university keep me quite busy.)
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2017 diyAudio
