Lightspeed Attenuator a new passive preamp
Old 18th June 2010, 04:45 PM   #3301
another simple solution is to insert a quiet/loud switch.
The switch bypasses a pair of 360k series resistors that reduce the current flowing to the series LEDs. Completely out of the audio signal stream.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th June 2010, 05:44 PM   #3302
wapo54001 is offline wapo54001  United States
Cool idea! I need to think about this one. Surely though, it changes the Zo by quite a lot. How does the downstream amplifier like this?
Karl
Old 18th June 2010, 06:51 PM   #3303
leaving the 360k in circuit is specifically for low level listening.
The output impedance of the signal side (when listening to low level signal) is largely determined by the Shunt LDR. The high value of the Series LDR hardly affects the impedance.
regards Andrew T.
Old 18th June 2010, 11:46 PM   #3304
The attenuation for the T attenuator at Zo=6k tops out at 88dB when R2=0. I need to rewrite the spreadsheet to allow different resistor values that would result in higher attenuation, even if the price is a higher Zo. But I'm guessing that 88dB is practically silent, isn't it?
Karl
Old 21st June 2010, 04:07 PM   #3305
maxw is offline maxw  United Kingdom
maxw's Avatar
What difference does the value of the pot make? Everyone seems to use 100K but what if I use 50k or 10k?
Old 21st June 2010, 04:14 PM   #3306
a low value pot can only put a low value resistance in the circuit formed by the regulated voltage source and the LED.
That results in a higher value of minimum current through the LEDs.
That reduces the range of attenuation available from the LDR/LED combination.
regards Andrew T.
Old 22nd June 2010, 02:18 PM   #3307
maxw's Avatar
Thanks for the explaination.
I want to use a digital pot to control the LDR but can't get a log one that is the right value so would there be any problem with using a 100k linear digital pot with a resistor across the input like this?
Old 22nd June 2010, 03:34 PM   #3308
Hmm, what would the ultimate curve look like after you combine the S-curve with the non-linear curve of the LDR module? Have you tried graphing the composite?
Karl
Old 22nd June 2010, 03:50 PM   #3309
maxw's Avatar
Karl
Not sure, only ordered my LDRs yesterday! I'll have a play when they arrive. With a 256 step digital pot there would be room to adjust the resulting curve in software. I'll be controlling the digital pot via I2C from an ardunio.
Old 22nd June 2010, 05:04 PM   #3310
udailey is offline udailey  United States
Passive Aggressive
That will work but you will want to make sure your wiper can handle the power.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2017 diyAudio
