Lightspeed Attenuator a new passive preamp - Page 504 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd April 2013, 10:52 AM   #5031
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Yes, I noticed that a series diode in front of the regulator would have prevented reserve polarity problems. I've got a few 5v reg circuits I can pop right in as a replacement. I'll be sure to add a few diodes.
What about running it from 2x 9v batteries?
Old 22nd April 2013, 03:02 PM   #5032
wlowes is offline wlowes  Canada
wlowes's Avatar
I run mine from a single 9v battery as a backup when I am messing up the regular supply. I just put a DC connector on the 9V just like the walwort so you can interchange. My standard is to run it from a linear power supply that is toroid to bridge rectifier then CLCRCLC filtered. Last but not least, 150uf Oscons right on the LDR pins also bumps it up. The linear supply is outboard and the last CLC filter before the low noise reg is onboard.
A battery has no ripple but actually a fairly high noise floor.
The regulator is a point to point zener emitter follower from TNT audio site. Also little bump in SQ over the 7805.
Old 25th April 2013, 05:25 AM   #5033
georgehifi's Avatar
Send a message via MSN to georgehifi
The quietest batteries I found were the rechargeable Lithium-Ion ones in the link, a 6800mA one last for weeks of listening before a 1/2hr recharge is needed. But please make sure if they are for the Lightspeed Attenuator I supply, that you ask the seller if the plug is 2.1mm to connect to the Lightspeed and that centre of the dc plug is + positive.
12vdc Li Rechargable | eBay
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 26th April 2013, 12:29 AM   #5034
lol, I've got one of those for my dac. Although, my dac isn't working anymore.
Old 10th May 2013, 07:19 AM   #5035
Rudi_Ratlos's Avatar
I want to add the level of attenuation of the Lightspeed Attenuator on my LCD-display, etched a little test-rig and measured Vout in relation
to the position of the wiper of the 100K potentiometer.
Since I do not own a precise 100K potentiometer I "simulated" it by 2 x 25 turns trim-potentiometers.
The reference input signal is 300mV. As a load I used the resistor input network (2K / 22K) of my FC-100 amplifier.
After 10 measurements I noticed that the LDRs behave very linearly.
A 1% decrease of the potentiometer's value (going from 100K -> 0K in 1K steps) results in a 1% increase (3mV) of Vout.
Is this really so? Do I have to measure any more?
Is my 300mV input signal a recommended value for any music-source?
Best regards - Rudi_Ratlos
Old 10th May 2013, 07:32 AM   #5036
This is my Lightspeed Attenuator PCB.
I have connected an OPAMP MCP6021 to the 100K potentiometer section wiper's output that drives the linear LDR.
Old 10th May 2013, 01:40 PM   #5037
Neat.
Old 13th May 2013, 02:46 PM   #5038
aeonsys is offline aeonsys  Canada
Hi Rudi, planning to offer your pcb board for sale. Thanks.
aeonsys
Old 13th May 2013, 04:34 PM   #5039
Rudi, I am looking at your photograph and the MCP602x datasheet. I guess the 8 pin DIP in the upper right corner is your 6021, but I can't visualize the function of a single op-amp in a circuit where there are two pot sections and four legs to be controlled. If the purpose was to offload managing the current from the pot onto the op-amp, I would think you'd use a 6022 or 6024 with two or four amps, so that can't be it. Could you tell me what that single op-amp does, please?
Old 15th May 2013, 08:10 PM   #5040
Default ebay lightspeed
hmm...
DIY PCB Light Speed Attenuator LDR NSL 32SR2 Pot Potentiometer Stepped Step | eBay
Copyright 1999-2017 diyAudio
