Lightspeed Attenuator a new passive preamp - Page 503 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th March 2013, 03:13 PM   #5021
udailey is offline udailey  United States
yeah its already in the casing. the other thing is that 40 ohms from this LDR is about as low as any LDR will go.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 26th March 2013, 11:08 PM   #5022
What is the cheapest way to build pre amplifier based LDR for testing vs Alps blue?
Anyone thinking of selling one?
Old 26th March 2013, 11:47 PM   #5023
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Hi, i've got 1 4 sale- check my signature.
Old 27th March 2013, 12:50 AM   #5024
George's Lightspeed circuit really couldnt get any less expensive unless you used a zener supply and no trimmers.
Old 27th March 2013, 03:44 AM   #5025
georgehifi's Avatar
Send a message via MSN to georgehifi
From memory this guy in his original ad said he just got a new production Lightspeed Attenuator from me, so he's selling his home made one, he's relisted it, and it's lower in price now.
Lightspeed attenuator - Canuck Audio Mart
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 27th March 2013, 11:58 AM   #5026
yes, that's me too. I never said it was an original.
Old 27th March 2013, 08:20 PM   #5027
georgehifi's Avatar
Misunterstanding, sorry merlin I did not mean you said the one your selling is original, I said it was home made, (diy).
Cheers George
Old 21st April 2013, 11:52 PM   #5028
Brought one of my lightspeed attenuators to the local GTA meetup and unfortunately had bad luck as my voltage regulator started smoking.
I thought I had brought the wrong adapter, but I checked it and got about 17vdc out of it (it's rated for 12v).
I've got to replace my voltage regulator (L7805ABV), but should I replace my adapter too? Is it putting out more voltage than the regulator can handle?
Old 22nd April 2013, 12:03 AM   #5029
georgehifi's Avatar
The Lightspeed's internal regulator is 5vdc 1amp and can take from 8-20vdc what happened was the polartity of the wall wart you bought was most probably - negative centre instead of + positive centre, if so this would take out the first electro cap around 100uf 25v and also the L7805 regulator. Should cost no more than ten dollars from a electronics shop, just remember which way the regulator was and also the cap.
Cheers George
Old 22nd April 2013, 12:58 AM   #5030
Better that there is a 1 amp series diode on the board, and appropriate instructions to constructors. Such a diode would alleviate dangerous reverse polarity circumstances
as can occur with reverse polarity and particularly electrolytic capacitors exposed to reverse polarity.
see; Troubleshooting analog circuits - Pease - Google Books
. Cheers / Chris
Copyright 1999-2017 diyAudio
