Lightspeed Attenuator a new passive preamp - Page 490 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th December 2012, 11:40 PM   #4891
albertli's Avatar
George,
Seems to me then if it was not a fluctuating heat issue, that can happen if instaled inside pre or poweramps.
No, mine is a separated / stand alone unit. I posted it on this thread but couldn't find it.
That maybe you could have had some very strong dc offset or test bench type audio signal come into the input or output that has given your ldr's a bit of a hammering, this can change their resistance character and unmatch them.
Don't understand either, It has been playing for me after finished. I didn't touch it until couple days ago.
Am I right from your pictures that you have separtate left and right led volume controls?
A single Alps dual 100k pot.
And did you say they were 1Kohm?
There was only one 1k trimmer on the louder side, but I put another one on to test after I found the problem.
Time to get another matched set.
Oh, is there anyway I could try / test it before I talk to Uriah for a new set.
Albert
Old 20th December 2012, 12:05 AM   #4892
georgehifi's Avatar
Send a message via MSN to georgehifi
It is possible that a dual 100k pot can have problems, but this would show in both channels equally, as a jump or lowering of both channels equally. But seeing you have a single dual pot and have wired it as I've shown in the Lightspeed Attenuator circuit, controlling both channels it takes the pot out of the equation because it's only happening on one of the channels.
Before installing another quad set of led/ldr's you could question your 1k trimmers they are far less costly to replace than the matched ldr's.
And btw you only need one trimmer, and it goes on the louder of the two channels.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 20th December 2012, 12:09 AM   #4893
albertli's Avatar
Originally Posted by georgehifi View Post
It is possible that the 100k pot can have problems, but this would show in both channels equally, as a jump or lowering of both channels euqally. But seeing you have a single dual pot and have wired it as I've shown in the Lightspeed Attenuator circuit, controlling both channels it takes the pot out of the equation because it's only happening on one of the channels.
Cheers George
thanks n I will change that trimmer asap. let U know.
Old 20th December 2012, 03:27 PM   #4894
albertli's Avatar
George,
After replacing the 1k trimmer on the louder side, the case remains. I then move to question the Alp volume pot. I couldn't find the dual 100k, but there are 2 single turn Bourne 100k pot, blue in color, sitting on the bench. I make the conversion in no time and it works perfect on test, and I put it to the system and it sings flawlessly well. The only drawback is the pots are not log pots and it's too sensitive to make adjustment. I just have to turn 2 mm to the volume I need. Is there anyway I could make improvement with these pots, or I have to buy new ones ????
Albert
Old 20th December 2012, 07:26 PM   #4895
georgehifi's Avatar
RV24BF-10-15R1-A100K Alpha (Taiwan) | Mouser
And they probably have the singles as well.
Cheers George
Old 20th December 2012, 07:27 PM   #4896
albertli's Avatar
Cheers George
big thanks
Old 20th December 2012, 07:47 PM   #4897
albertli's Avatar
Cheers George
big thanks
Old 21st December 2012, 04:01 PM   #4898
albertli's Avatar
George,
I brought 2 single A100k pots in local store to replace the Bourne and now I have more room to tune. Everything back to normal as before. I can recall I read somewhere that you mentioned I should put the volume half way when not in use, say 12 o'clock. I'd love to know more since my intention is to keep it on 24/7.
Albert
Old 21st December 2012, 08:34 PM   #4899
georgehifi's Avatar
Good to see you have got it going again, but you know you still have a damaged/unmatched set of ldr's, but by using separate l & R volume controls you have, band-aid fixed your problem.
Yes volume left at the half way posistion will turn on the led's at only half brightness when your not using it, and hence make them last twice as long.
Cheers George
Old 21st December 2012, 08:54 PM   #4900
georgehifi's Avatar
Funny I just got an diyaudio pm/email from "shaker" I don't know if that's his forum name or not but he has not activated his return pm via this forum.
He asks
"Hello,
I wanted to ask you (being the designer), is there any way I can use unmatched resistors? How can I do it and get away with it. I can solve this issue in case I understood what to do, I can use controllers, may be this helps?
thanks"
Shaker by unmatched resistors I asume you mean unmated ldr's, to answer your question, you can get around it depending how unmatched they are by doing what Albertli did above by using separate l & r volume controls.
PS Just found out his forum name is "metal"
Cheers George
Copyright 1999-2017 diyAudio
